1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV gateway renders PVs as disconnected
To: <[email protected]>
Date: Wed, 28 Mar 2018 07:10:18 -0500
Also starting the gateway with the "-log gateway.log" option does provide
information about how the gateway is configured and may also provide some
error/warning messages as well.
The gateway configuration information is provided in the header of the log file.
Marty
On 03/28/2018 06:54 AM, Ralph Lange wrote:
Hi Abdalla,
How is that CA Gateway configured?
(Even when started without command line arguments, a Gateway usually needs configuration.)
~Ralph
On Wed, Mar 28, 2018 at 1:48 PM, Abdalla Ahmad <[email protected] <mailto:[email protected]>> wrote:
    Hi____
    __ __
    We are running the gateway on a virtual server with 1 network interface,
    this server can see all the different LANs (office, machine, beamlines,
    etc.) through routing rules and access lists done by the IT group. When the
    gateway is running, after a while entire IOCs gets disconnected. We are
    running the gateway with no arguments but in the .bashrc file we are
    defining EPICS_CA_ADDR_LIST having the IP address for the gateway to look at
    (Not all IOCs). This behavior happened when having all IOCs or some of them
    in the address list.____
    __ __
    I came upon this video from APS https://www.youtube.com/watch?v=Y5Ge89Y4d1E
    <https://www.youtube.com/watch?v=Y5Ge89Y4d1E> In which, as I understood,
    they have multiple gateways running on the server with each gateway connects
    one network interfaces together to the other interfaces. So my questions
    are:____
    __1.__What is happening with our setup? Some CA loops happens at some point?____
    __2.__Is having a network interface per VLAN optional or recommended?____
    __ __
    Best Regards,____
    __ __
    Abdalla Ahmad____
    Control Engineer____
    SESAME____
    Allan, Jordan.____
    Tel: (+962-5) 3511348 , ext. 265 <tel:+962%205%20351%201348>____
    Fax: (+962-5) 3511423 <tel:+962%205%20351%201423>____
    Mob: (+962-7)88183296 <tel:+962%207%208818%203296>____
    www.sesame.org.jo <http://www.sesame.org.jo/>____
    __ __
PV gateway renders PVs as disconnected Abdalla Ahmad
Re: PV gateway renders PVs as disconnected Ralph Lange
Prev: Re: PV gateway renders PVs as disconnected Ralph Lange
Next: Re: PV gateway renders PVs as disconnected Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: PV gateway renders PVs as disconnected Abdalla Ahmad
ANJ, 28 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
