1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PV gateway renders PVs as disconnected
To: Paul Sichta <[email protected]>
Date: Wed, 28 Mar 2018 12:18:53 +0000
Hi Paul
The monitoring was ok but they were getting disconnected at some point. And I think something weird happened is that some PCs getting disconnected PVs and some PCs everything works fine.
Best Regards,
Abdalla.
Sent: Wednesday, March 28, 2018 2:18 PM
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Subject: Re: PV gateway renders PVs as disconnected
Abdalla,
I had a similar problem with some CA clients back in 2000  (titled CA Server disconnects) so this is a longshot...
Back then I had a repeatable time-to-disconnect of 2 hours, 11 minutes, and 15 seconds; could it be due to no CA activity from your IOC to the client side of the gateway.  Are all client-monitored values on the affected IOC never changing for long periods?
-ps
On Wed, Mar 28, 2018 at 7:48 AM, Abdalla Ahmad <[email protected]> wrote:
Hi
We are running the gateway on a virtual server with 1 network interface, this server can see all the different LANs (office, machine, beamlines, etc.) through routing rules and access lists done by the IT group. When the gateway is running, after a while entire IOCs gets disconnected. We are running the gateway with no arguments but in the .bashrc file we are defining EPICS_CA_ADDR_LIST having the IP address for the gateway to look at (Not all IOCs). This behavior happened when having all IOCs or some of them in the address list.
I came upon this video from APS https://www.youtube.com/watch?v=Y5Ge89Y4d1E In which, as I understood, they have multiple gateways running on the server with each gateway connects one network interfaces together to the other interfaces. So my questions are:
1.       What is happening with our setup? Some CA loops happens at some point?
2.       Is having a network interface per VLAN optional or recommended?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Re: PV gateway renders PVs as disconnected Martin L. Smith
PV gateway renders PVs as disconnected Abdalla Ahmad
Re: PV gateway renders PVs as disconnected Paul Sichta
Prev: Re: PV gateway renders PVs as disconnected Paul Sichta
Next: Re: PV gateway renders PVs as disconnected Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
