1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 Compilation in windows-64
To: Vishnu Patel <[email protected]>, techtalk <[email protected]>
Date: Fri, 13 Apr 2018 10:46:28 +0000
Hi Vishnu,
The errors you are reporting here are identical to the errors you reported in this tech-talk thread on January 25, 2018.
https://epics.anl.gov/tech-talk/2018/msg00131.php
You never told us how you fixed the problems that time.  I suspect the same fix will work this time.
From: [email protected] <[email protected]> on behalf of Vishnu Patel <[email protected]>
Sent: Friday, April 13, 2018 3:20 AM
To: techtalk
Subject: EPICS 7 Compilation in windows-64
I am not able to compile epics_base7.0.1.1 on winodws 10 machine.
make[1]: Entering directory `c:/epics/base-7.0.1.1/test'
make -C ./tools install
make[2]: Entering directory `c:/epics/base-7.0.1.1/test/tools'
perl -CSD c:/epics/base-7.0.1.1/bin/windows-x64/makeMakefile.pl O.windows-x64 ../../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
            T_A=windows-x64 install
make[3]: Entering directory `c:/epics/base-7.0.1.1/test/tools/O.windows-x64'
perl -CSD c:/epics/base-7.0.1.1/bin/windows-x64/expandVars.pl -t ../../.. -a windows-x64 ../Snippets.plt Snippets.t
make[3]: Leaving directory `c:/epics/base-7.0.1.1/test/tools/O.windows-x64'
make[2]: Leaving directory `c:/epics/base-7.0.1.1/test/tools'
make[1]: Leaving directory `c:/epics/base-7.0.1.1/test'
make -C ./modules install
make[1]: Entering directory `c:/epics/base-7.0.1.1/modules'
Creating RELEASE.windows-x64.local, EPICS_BASE = c:/epics/base-7.0.1.1
make -C ./libcom install
Can't open perl script ".": Permission denied
make[2]: Entering directory `c:/epics/base-7.0.1.1/modules/libcom'
make -C ./configure install
Can't open perl script "..": Permission denied
make[3]: Entering directory `c:/epics/base-7.0.1.1/modules/libcom/configure'
perl -CSD c:/epics/base-7.0.1.1/modules/libcom/configure/c:/epics/base-7.0.1.1/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
Can't open perl script "c:/epics/base-7.0.1.1/modules/libcom/configure/c:/epics/base-7.0.1.1/bin/windows-x64/makeMakefile.pl": Invalid argument
make[3]: *** [O.windows-x64] Error 22
make[3]: Leaving directory `c:/epics/base-7.0.1.1/modules/libcom/configure'
make[2]: *** [configure.install] Error 2
make[2]: Leaving directory `c:/epics/base-7.0.1.1/modules/libcom'
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory `c:/epics/base-7.0.1.1/modules'
make: *** [modules.install] Error 2
make: Leaving directory `c:/epics/base-7.0.1.1'
Thanks
Vishnu
Re: EPICS 7 Compilation in windows-64 Vishnu Patel
Prev: RE: EPICS 7 Compilation in windows-64 Freddie Akeroyd - UKRI STFC
Next: RE: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7 Compilation in windows-64 Vishnu Patel
Next: Re: EPICS 7 Compilation in windows-64 Vishnu Patel
ANJ, 16 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
