1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: using epics-base with yocto
To: "'Dirk Zimoch'" <[email protected]>, <[email protected]>
Date: Wed, 25 Apr 2018 10:25:09 +0200
Hello Dirk:
Many thanks for your help!
Did you implement a layer/recipes for yocto?
Regards, Mariano
-----Original Message-----
Behalf Of Dirk Zimoch
Sent: Wednesday, April 25, 2018 10:19 AM
To: [email protected]
Subject: Re: using epics-base with yocto
Hello Mariano,
I compile EPICS with Yocto 2.1 / Petalinux toolchain for the XILINX Zynq
Ultrascale.
My config file is attached. But it needs 3 additional macros:
GNU_HOST_ARCH=i686
GNU_HOST_OS=linux
are defined in my CONFIG_SITE.linux-x86.Common
GNU_HOST_ARCH_64=x86_64
is defined in my CONFIG_SITE.linux-x86_64.Common
(I use them in several embedded Linux cross compiler configs and did not
want to pull too many host specifics into a CONFIG.Common.* file.)
Also be aware that you have probably installed yocto somewhere else. Fix
SDK_DIR accordingly.
I could use this cross compiler only on a 64 bit host, but that should not
be much of a problem nowadays.
Best regards,
Dirk
On 24.04.2018 15:45, Mariano Ruiz wrote:
> Dear tech-talkers,
> I am trying to create a Linux embedded distribution using Yocto
> including epics-base.
> Does anyone have a yocto meta-layer already implemented?
> Thanks a lot
> Mariano Ruiz
> Professor
> Technical University of Madrid
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campai
gn=sig-email&utm_content=emailclient&utm_term=icon>
> 	Virus-free. www.avast.com
> campaign=sig-email&utm_content=emailclient&utm_term=link>
> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
Re: using epics-base with yocto Dirk Zimoch
using epics-base with yocto Mariano Ruiz
Prev: Re: using epics-base with yocto Dirk Zimoch
Next: Re: using epics-base with yocto Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 25 Apr 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
