1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using epics-base with yocto
To: <[email protected]>
Date: Wed, 25 Apr 2018 10:18:40 +0200
Hello Mariano,
I compile EPICS with Yocto 2.1 / Petalinux toolchain for the XILINX Zynq Ultrascale.
My config file is attached. But it needs 3 additional macros:
GNU_HOST_ARCH=i686
GNU_HOST_OS=linux
are defined in my CONFIG_SITE.linux-x86.Common
GNU_HOST_ARCH_64=x86_64
is defined in my CONFIG_SITE.linux-x86_64.Common
(I use them in several embedded Linux cross compiler configs and did not want to pull too many host specifics into a CONFIG.Common.* file.)
Also be aware that you have probably installed yocto somewhere else. Fix SDK_DIR accordingly.
I could use this cross compiler only on a 64 bit host, but that should not be much of a problem nowadays.
Best regards,
Dirk
On 24.04.2018 15:45, Mariano Ruiz wrote:
Dear tech-talkers,
I am trying to create a Linux embedded distribution using Yocto including epics-base.
Does anyone have a yocto meta-layer already implemented?
Thanks a lot
Mariano Ruiz
Professor
Technical University of Madrid
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon> Virus-free. www.avast.com <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
# XILINX Zynq with Yocto 2.1 / Petalinux toolchain
# Include definitions common to all Linux targets
include $(CONFIG)/os/CONFIG.Common.linuxCommon
COMMANDLINE_LIBRARY = READLINE
ARCH_CLASS = arm64
SDK = petalinux
SDK_DIR = /opt/petalinux-gfa/2017.2
SDK_HOST_ARCH = $(GNU_HOST_ARCH_64)-$(SDK)-$(GNU_HOST_OS)
SDK_TARGET = aarch64-xilinx-linux
GNU_TARGET = $(SDK_TARGET)
SDKTARGETSYSROOT = $(SDK_DIR)/sysroots/$(SDK_TARGET)
GNU_DIR = $(SDK_DIR)/sysroots/$(SDK_HOST_ARCH)/usr
GNU_BIN = $(GNU_DIR)/bin/$(GNU_TARGET)
ARCH_DEP_CPPFLAGS = --sysroot=$(SDKTARGETSYSROOT)
ARCH_DEP_LDFLAGS = --sysroot=$(SDKTARGETSYSROOT)
RE: using epics-base with yocto Mariano Ruiz
Prev: Modify checkbox value from a table widget Pilar Gil Jaldo
Next: RE: using epics-base with yocto Mariano Ruiz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: using epics-base with yocto Mariano Ruiz
ANJ, 25 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
