Hello,
I'm having problem while trying to modify the checkbox value
from a table widget from a python script. And I would like to
know if it is possible to do it.
Write now I have a table:
tab = display.getWidget("Table").getTable()
And for enable the checkbox I'm using following command.
tab.setCellText( 1, 1, "Yes")
The problem that I have is that I can see "Yes" written on the
table, but the checkbox is not enabled.
Has someone of you handle before with such a problem?
Thank you very much in advance!
Pilar
Pilar Gil Jaldo
Embedded SW Engineer
[email protected] - Seven
Solutions
"This e-mail and any materials attached here to, including,
without limitation, all content hereof and thereof are
confidential and proprietary to Seven Solutions,S.L and/or its
affiliates, and are confidential. Without the prior
written consent of Seven Solutions, this content may not (i) be
disclosed to any third party, (ii) be reproduced, modified or
otherwise used by anyone other than current employees of Seven
Solutions or its affiliates. If you are not the intended
recipient or if this message has been received in error, please
immediately notify us via e-mail and delete it."
