1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Stringin - asynOctedRead type how to set string length
Date: Tue, 5 Jun 2018 11:53:59 +0200
Hello,
I would like to know if it is possible to set the size of stringin record which type is DTYP=asynOctetRead.
Do the stringin records have a parameter such as "LEN" or something similar?
I have been looking in the documentation and I have not found this information.
Thank you very much in advance!
Pilar
Pilar Gil Jaldo
Embedded SW Engineer
[email protected] - Seven Solutions
"This e-mail and any materials attached here to, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are confidential. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it."
Re: Stringin - asynOctedRead type how to set string length Mark Rivers
Modify checkbox value from a table widget Pilar Gil Jaldo
Prev: Re: Parsing problem with stream Lucock, Richard M
Next: Re: Stringin - asynOctedRead type how to set string length Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Modify checkbox value from a table widget Kasemir, Kay
ANJ, 05 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
