Hi Mark and all, I used sscan-2-10-1( 2D scan ), base 3.15. I always got "Waiting for pv's to connect" after I clicked the "scan" in scan1. But it work fine when I disable the saveData in st.cmd with the same setting. It could do the scan 1 and scan 2. So I think the error was saveData. But saveData should be easy. The error was "I/O error, can't open file" though I am root. The following was some strange message I got. When I set the parameters, I got these message in st.cmd. ******************************* dbpf("xxx:scan1.R1PV", "xxx:m1.RBV") DBR_STRING: "xxx:m1.RBV" dbpf("xxx:scan1.P1PV", "xxx:m1.VAL") DBR_STRING: "xxx:m1.VAL" dbpf("xxx:scan1.T1PV", "xxx:m2.EXSC") DBR_STRING: "xxx:m2.EXSC" dbpf("xxx:scan2.R1PV", "xxx:m2.RBV") DBR_STRING: "xxx:m2.RBV" dbpf("xxx:scan2.P1PV", "xxx:m2.VAL") DBR_STRING: "xxx:m2.VAL" dbpf("xxx:scan2.T1PV", "XSPRESS3-EXAMPLE:HDF5:Capture") xxx:scan2:special:connect already in progress for link T1. Waiting... (The sentence came out sometime, 50%) DBR_STRING: "XSPRESS3-EXAMPLE:HDF5:Capture" dbpf("xxx:scan2.T2PV", "XSPRESS3-EXAMPLE:Acquire") DBR_STRING: "XSPRESS3-EXAMPLE:Acquire" motorUtilInit('xxx:') saveData_Init(saveData.req, 'P=xxx:') saveData: message queue created saveData:maxAllowedRetries = 10 saveData:retryWaitInSecs = 15 seq &scanProgress, 'S=xxx:, P=xxx:scanProgress:' sevr=info Sequencer release 2.2.4, compiled Sun Apr 15 20:26:45 2018 sevr=info Spawning sequencer program "scanProgress", thread 0x26a0de0: "scanProgress" # write all the PV names to a local file dbl > dbl-all.txt # Report states of database CA links #dbcar(*,1) # print the time our boot was finished date 2018/05/01 23:01:14.875178 asynSetTraceIOMask("L0",0,2) asynSetTraceMask("L0",0,9) sevr=info scanProgress[0]: all channels connected & received 1st monitor " Source File: ../cac.cpp line 1298 Current Time: Tue May 01 2018 23:01:14.903656005 .................................................................. CA.Client.Exception............................................... Warning: "Identical process variable names on multiple servers" Context: "Channel: "XSPRESS3-EXAMPLE:HDF5:Capture", Connecting to: 192.168.0.1:5064, Ignored: 192.168.1.106:5064" Source File: ../cac.cpp line 1298 Current Time: Tue May 01 2018 23:01:14.902491275 .................................................................. CA.Client.Exception............................................... Warning: "Identical process variable names on multiple servers" Context: "Channel: "XSPRESS3-EXAMPLE:Acquire", Connecting to: Then I click the stop button to stop. I saw these. It should not be like these. I do have the permission since I am always root. ************************************** saveData: ...will retry in 15 seconds saveData:writeScanRecCompleted(xxx:scan1): can't open data file!! saveData: ...will retry in 15 seconds saveData:writeScanRecCompleted(xxx:scan1): can't open data file!! saveData: ...will retry in 15 seconds saveData: too many retries; abandoning data from scan 'xxx:scan1' saveData: ******************************************* Regards, Li xing
ANJ, 01 May 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
