1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error LNK2005 building Diamond's nullhttpd module on Windows
From: Freddie Akeroyd - UKRI STFC <[email protected]>
To: "'J. Lewis Muir'" <[email protected]>, 'EPICS Tech-Talk' <[email protected]>
Date: Wed, 16 May 2018 22:36:24 +0000
Hi Lewis,
We are using ffmpegServer on windows, I had to make a few changes to get it all to work which I apologise for not feeding back to the community yet.  Our code is in https://github.com/ISISComputingGroup/EPICS-areaDetector if that helps. If I recall correctly you do not need to build nullhttp as a separate module, the source files are included directly by the Makefile for ffmpegServer.
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of J. Lewis Muir
Sent: 16 May 2018 23:22
To: EPICS Tech-Talk
Subject: Re: Error LNK2005 building Diamond's nullhttpd module on Windows
On 05/16, J. Lewis Muir wrote:
> It was noted in a private email that the <nullhttpd>/src/nullhttpd.h
> header contains the following lines in a WIN32 ifdef which appear to
> add a library-search record to the object file and define _MT to 1:
> #pragma comment(lib, "libcmt.lib")
> #pragma comment(lib, "wsock32.lib")
> #define _MT 1
> I tried reverting the "/NODEFAULTLIB:LIBCMT.lib" change and commenting
> out the "libcmt.lib" pragma line and the _MT define line, but still no
> dice; it's the same error I got after making the
> "/NODEFAULTLIB:LIBCMT.lib" change (full output at the end of this
> email):
> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release       -implib:nullhttpd.lib -out:nullhttpd.dll         cgi.obj files.obj http.obj win32.obj config.obj format.obj server.obj main.obj
> server.obj : error LNK2001: unresolved external symbol
> __imp__MessageBoxA@16 ===
After more web searching, I tried adding the following to the WIN32 ifdef in <nullhttpd>src/nullhttpd.h:
#pragma comment(lib, "user32.lib")
And now it compiles successfully!
But this is just a bunch of hacking; I don't know enough about Windows to know what's the right thing to do.  I'll report back once I have things narrowed down a bit.
Lewis
Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Re: Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Prev: Re: Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Next: RE: Error LNK2005 building Diamond's nullhttpd module on Windows Freddie Akeroyd - UKRI STFC
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: QEgui strip chart question marc . lormand
ANJ, 16 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
