1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error LNK2005 building Diamond's nullhttpd module on Windows
To: "'[email protected]'" <[email protected]>
Date: Fri, 18 May 2018 13:43:49 +0000
It's been years since we last built this at DLS (2015) so Freddie's github repo is probably the most up-to-date. https://github.com/ISISComputingGroup/EPICS-nullhttpd
Its a bit of a strange setup: It seems the nullhttpd module doesn't have to be built as the sources are pulled into ffmpegServer at build time and rebuilt there. See https://github.com/areaDetector/ffmpegServer/blob/master/ffmpegServerApp/src/Makefile#L27
Also there are some comments in that makefile about nullhttpd requires win32 mode (-DWIN32)...
Cheers,
Ulrik
From: [email protected] <[email protected]> on behalf of Freddie Akeroyd - UKRI STFC <[email protected]>
Sent: 17 May 2018 00:19
To: 'Andrew Johnson'; '[email protected]'
Subject: RE: Error LNK2005 building Diamond's nullhttpd module on Windows
There are some fixes for these issue pushed to https://github.com/ISISComputingGroup/EPICS-nullhttpd
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: 16 May 2018 22:59
To: [email protected]
Hi Lewis,
I know nothing about nullhttpd, but...
On 05/16/2018 04:41 PM, J. Lewis Muir wrote:
> Now I'm getting the following error (the full output is at the end of
> this email):
> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release   /NODEFAULTLIB:LIBCMT.lib     -implib:nullhttpd.lib -out:nullhttpd.dll         cgi.obj files.obj http.obj win32.obj config.obj format.obj server.obj main.obj
> server.obj : error LNK2001: unresolved external symbol
> __imp__MessageBoxA@16 ===
> Ideas?
MessageBoxA() is a MS Windows call to bring up an alert box, and is found in user32.dll. You could try linking to that library.
> cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3     -DWIN32    -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\include\\os\\WIN32 -I..\\..\\include -IC:\opt\epics-base\\include\\os\\WIN32 -IC:\opt\epics-base\\include          ..\\server.c
> server.c
> ..\server.c(46) : warning C4133: 'function' : incompatible types - from 'long *' to 'const time_t *'
> ..\server.c(70) : warning C4133: 'function' : incompatible types - from 'long *' to 'const time_t *'
> ..\server.c(447) : warning C4244: '=' : conversion from 'time_t' to
> 'int', possible loss of data
Those warnings look rather ominous, I would suggest investigating them to make sure they aren't going to cause problems. The time_t type on Windows may have changed from 32 to 64-bit since this code was written.
HTH,
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Re: Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
Re: Error LNK2005 building Diamond's nullhttpd module on Windows Andrew Johnson
RE: Error LNK2005 building Diamond's nullhttpd module on Windows Freddie Akeroyd - UKRI STFC
Prev: Re: EPICS control of an Edwards STP turbomolecular pump kurt goetze
Next: Store 64-bit integer in asyn parameter library? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Error LNK2005 building Diamond's nullhttpd module on Windows Freddie Akeroyd - UKRI STFC
Next: Re: Error LNK2005 building Diamond's nullhttpd module on Windows J. Lewis Muir
ANJ, 18 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
