1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: msi "Could not open" error on Windows with file absolute path
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 22 May 2018 16:46:23 -0500
Hello, all.
On Windows, when msi is used to expand a template substitution file that
looks like:
file C:\tmp2\dbExample1.db
pattern { user }
  { "luke" }
it produces an error (the full output is at the end of this email):
gmake[3]: Entering directory 'C:/tmp/myModuleApp/Db/O.win32-x86'
echo "../O.Common/dbExampleMerge.db : " >> dbExampleMerge.db.d
echo "dbExampleMerge.db.d: " >> dbExampleMerge.db.d
"Inflating database from ../dbExampleMerge.substitutions "
msi    -I. -I.. -I../O.Common -I../../../db -IC:/opt/epics-base/db -S../dbExampleMerge.substitutions  > dbExampleMerge.tmp
Could not open C:\tmp2\dbExample1.db
input:   which is
gmake[3]: *** [C:/opt/epics-base/configure/RULES.Db:318: ../O.Common/dbExampleMerge.db] Error 1
gmake[3]: Leaving directory 'C:/tmp/myModuleApp/Db/O.win32-x86'
The problem seems to be related to the absolute pathname for the file
directive in the template substitution file.  If I change it to a
relative path (i.e., file ..\..\tmp2\dbExample1.db) it works.  However,
I need to be able to use an absolute path.
Does anyone know what's wrong and how to fix this?
To reproduce this on Windows:
C:\>call C:\opt\epics-base\startup\win32.bat
C:\>mkdir tmp
C:\tmp>cd tmp
C:\tmp>makeBaseApp.pl -t example myModule
C:\tmp>makeBaseApp.pl -i -t example myModule
C:\tmp>cd ..
C:\>mkdir tmp2
C:\>copy tmp\myModuleApp\Db\dbExample1.db tmp2
C:\>copy tmp\myModuleApp\Db\dbExample2.db tmp2
Create the file C:\tmp\myModuleApp\Db\dbExampleMerge.substitutions:
pattern { user }
  { "luke" }
file C:\tmp2\dbExample2.db
pattern { user, no, scan }
  { "han", "1", "5 second" }
Add the following line, below the "DB += userHost.substitutions" line,
to C:\tmp\myModuleApp\Db\Makefile:
DB += dbExampleMerge.db
Build:
C:\>cd tmp
C:\tmp>gmake
Environment:
* 32-bit Windows 7 Pro
* Visual Studio C++ 2010 Express SP1
* 32-bit Strawberry Perl 5.26.2.1
* EPICS Base 3.14.12.7 + Known Problems patches
* msi 1-7 + Andrew Johnson's patch from [1]
* EPICS_HOST_ARCH=win32-x86
Thank you!
Lewis
[1] https://epics.anl.gov/tech-talk/2015/msg01691.php
C:\tmp>gmake
gmake: Entering directory 'C:/tmp'
gmake -C ./configure install
gmake[1]: Entering directory 'C:/tmp/configure'
perl C:/opt/epics-base/bin/win32-x86/makeMakefile.pl O.win32-x86 ../..
perl -MExtUtils::Command -e mkpath O.Common
gmake -C O.win32-x86 -f ../Makefile TOP=../.. \
    T_A=win32-x86 install
gmake[2]: Entering directory 'C:/tmp/configure/O.win32-x86'
perl C:/opt/epics-base/bin/win32-x86/convertRelease.pl checkRelease
gmake[2]: Leaving directory 'C:/tmp/configure/O.win32-x86'
gmake[1]: Leaving directory 'C:/tmp/configure'
gmake -C ./myModuleApp install
gmake[1]: Entering directory 'C:/tmp/myModuleApp'
gmake -C ./src install
gmake[2]: Entering directory 'C:/tmp/myModuleApp/src'
perl C:/opt/epics-base/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
gmake -C O.win32-x86 -f ../Makefile TOP=../../.. \
gmake[3]: Entering directory 'C:/tmp/myModuleApp/src/O.win32-x86'
perl C:/opt/epics-base/bin/win32-x86/makeIncludeDbd.pl base.dbd xxxSupport.dbd dbSubExample.dbd myModuleHello.dbd initTrace.dbd myModuleInclude.dbd
echo "../O.Common/myModuleInclude.dbd : ../Makefile" >> myModule.dbd.d
"Expanding dbd"
"Installing dbd file ../../../dbd/xxxSupport.dbd"
mkdir ../../../dbd
"Installing created dbd file ../../../dbd/myModule.dbd"
"Installing dbd file ../../../dbd/xxxRecord.dbd"
echo "../O.Common/xxxRecord.h : ../Makefile" >> xxxRecord.h.d
C:\\opt\\epics-base\\bin\\win32-x86\\dbToRecordtypeH.exe   -I. -I.. -I../O.Common -I../../../dbd -IC:/opt/epics-base/dbd ../xxxRecord.dbd xxxRecord.h
"Installing generated generic include file ../../../include/xxxRecord.h"
mkdir ../../../include
cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\xxxRecord.c
xxxRecord.c
..\xxxRecord.c(211) : warning C4244: '=' : conversion from 'epicsFloat64' to 'float', possible loss of data
cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\devXxxSoft.c
devXxxSoft.c
cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\dbSubExample.c
dbSubExample.c
cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\myModuleHello.c
myModuleHello.c
cl -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD     -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\initTrace.c
initTrace.c
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref -release       -implib:myModuleSupport.lib -out:myModuleSupport.dll         xxxRecord.obj devXxxSoft.obj dbSubExample.obj myModuleHello.obj initTrace.obj      C:\\opt\\epics-base\\lib\\win32-x86\\recIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\softDevIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\miscIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\rsrvIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbtoolsIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\asIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\registryIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbStaticIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\ca.lib  C:\\opt\\epics-base\\lib\\win32-x86\\Com.lib
   Creating library myModuleSupport.lib and object myModuleSupport.exp
Generating code
Finished generating code
"Installing shared library ../../../bin/win32-x86/myModuleSupport.dll"
mkdir ../../../bin/win32-x86
"Installing library ../../../lib/win32-x86/myModuleSupport.lib"
mkdir ../../../lib/win32-x86
perl C:/opt/epics-base/bin/win32-x86/registerRecordDeviceDriver.pl ../O.Common/myModule.dbd myModule_registerRecordDeviceDriver C:/tmp > myModule.tmp
perl -MExtUtils::Command -e mv myModule.tmp myModule_registerRecordDeviceDriver.cpp
cl -EHsc -GR -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD  -TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        myModule_registerRecordDeviceDriver.cpp
cl -EHsc -GR -c                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD  -TP   -I. -I..\\O.Common -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IC:\\opt\\epics-base\\include\\os\\WIN32 -IC:\\opt\\epics-base\\include        ..\\myModuleMain.cpp
myModuleMain.cpp
link -nologo  -LTCG -incremental:no -opt:ref -release               -out:myModule.exe        myModule_registerRecordDeviceDriver.obj myModuleMain.obj     ..\\..\\..\\lib\\win32-x86\\myModuleSupport.lib  C:\\opt\\epics-base\\lib\\win32-x86\\recIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\softDevIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\miscIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\rsrvIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbtoolsIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\asIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\registryIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\dbStaticIoc.lib  C:\\opt\\epics-base\\lib\\win32-x86\\ca.lib  C:\\opt\\epics-base\\lib\\win32-x86\\Com.lib
Generating code
"Installing created file ../../../bin/win32-x86/myModule.exe"
gmake[3]: Leaving directory 'C:/tmp/myModuleApp/src/O.win32-x86'
gmake[2]: Leaving directory 'C:/tmp/myModuleApp/src'
gmake -C ./Db install
gmake[2]: Entering directory 'C:/tmp/myModuleApp/Db'
input:   which is
gmake[2]: *** [C:/opt/epics-base/configure/RULES_ARCHS:61: install.win32-x86] Error 2
gmake[2]: Leaving directory 'C:/tmp/myModuleApp/Db'
gmake[1]: *** [C:/opt/epics-base/configure/RULES_DIRS:83: Db.install] Error 2
gmake[1]: Leaving directory 'C:/tmp/myModuleApp'
gmake: *** [C:/opt/epics-base/configure/RULES_DIRS:83: myModuleApp.install] Error 2
gmake: Leaving directory 'C:/tmp'
Re: msi "Could not open" error on Windows with file absolute path Johnson, Andrew N.
Prev: Is it possible to make an IOC for an HTTP device? Sobhani, Bayan
Next: RE: [UNTRUSTED] Problem accessing TextUpdate text property in Display Builder script. Gregory, Ray
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is it possible to make an IOC for an HTTP device? Rod Nussbaumer
Next: Re: msi "Could not open" error on Windows with file absolute path Johnson, Andrew N.
ANJ, 22 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
