1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is it possible to make an IOC for an HTTP device?
To: [email protected]
Date: Tue, 22 May 2018 16:10:59 -0700
Iff the interface is strictly HTML, then it can be do-able using streamDevice, but it can be tricky, too. If the device has layers of pages to get through before the data of interest is available, then it gets very difficult. I did this with a simple device once, and it worked fairly well. When we purchased another ostensibly identical device, it failed, and I never got it working because the 'HTML' data was sent using Javascript that drew dots like a dot matrix display on the web page, so it would look like one of those 4 line X 20 character LCDs that was one the physical front panel of the device.
Rod Nussbaumer
TRIUMF
Vancouver, Canada
On 05/22/2018 02:42 PM, Sobhani, Bayan wrote:
I am looking at this device:
https://www.embeddeddatasystems.com/HA7Net--Ethernet-1-Wire-Host-Adapter_p_22.html
It says that communication is done with the HTTP protocol  - is this significant? Would it be doable for me to make an IOC that uses let’s say StreamDevice to communicate with this?
Alex
Is it possible to make an IOC for an HTTP device? Sobhani, Bayan
Prev: Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
Next: Re: msi "Could not open" error on Windows with file absolute path Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is it possible to make an IOC for an HTTP device? Eric Norum
Next: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
ANJ, 22 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
