1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is it possible to make an IOC for an HTTP device?
To: Freddie Akeroyd - UKRI STFC <[email protected]>
Date: Tue, 22 May 2018 15:30:27 -0700
You may also need to specify the ‘http’ option on the drvAsynIPPortConfigure host argument to get the asyn driver to set up and tear down the TCP connection for each transaction.
On May 22, 2018, at 3:19 PM, Freddie Akeroyd - UKRI STFC <[email protected]> wrote:
As Lewis says, Stream device can work for many cases - there is an example at http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#web
If you find you need something more complicated, drop me a direct email as I have had need to combine asyn with libxml2, curl & htmltidy in the past to scrape a web page using XPath expressions and I might be able to point you at something usable
Freddie
Eric Norum
[email protected]
Is it possible to make an IOC for an HTTP device? Sobhani, Bayan
Re: Is it possible to make an IOC for an HTTP device? J. Lewis Muir
RE: Is it possible to make an IOC for an HTTP device? Freddie Akeroyd - UKRI STFC
Prev: RE: Is it possible to make an IOC for an HTTP device? Freddie Akeroyd - UKRI STFC
Next: Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Is it possible to make an IOC for an HTTP device? Rod Nussbaumer
ANJ, 22 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
