1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: Transfering array of 256 elements to driver
To: 'Jörn Dreyer' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 May 2018 17:08:36 +0000
Just to be clear your record should be:
record(waveform, $(P)$(R)$(I):DelayTimeA) {
	field (DESC,	"Delay of channel A")
	field (DTYP,	"asynInt32ArrayOut")
	field (INP,	"@asyn($(PORT), 0, 100) DELAYTIMEA")
	field (FTVL, 	"LONG")
	field (NELM, 	"256")
I changed OUT to INP and asnyInt32ArrayOut to asynInt32ArrayOut.
-----Original Message-----
Sent: Thursday, May 31, 2018 8:28 AM
To: [email protected]
Cc: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Transfering array of 256 elements to driver
Hi Mark and Michael,
her is how I configured the waveform record:
	field (DTYP,	"asnyInt32ArrayOut")
	field (OUT,		"@asyn($(PORT), 0, 100) DELAYTIMEA")
	field (NELM, 	"256")
At IOC startup I get the following error message:
>Can't set "XXX:Test1:DelayTimeA.DTYP" to "asnyInt32ArrayOut"
>Error at or before ")" in file "db/Delay.db" line 355 Record
>"XXX:Test1:DelayTimeA" does not have a field "OUT"
This somehow contradicts the information. And the record reference manual defines also onle the INP field for the waveform record.
Jörn
Am Donnerstag, 31. Mai 2018, 15:01:35 CEST schrieb Mark Rivers:
> Hi Jörn
> > The waveform record supports only INP direction.
> The devAsynInt32Array.dbd file defines both input and output.
> corvette:asyn/asyn/devEpics>more devAsynInt32Array.dbd
> device(waveform,INST_IO,asynInt32ArrayWfIn,"asynInt32ArrayIn")
> device(waveform,INST_IO,asynInt32ArrayWfOut,"asynInt32ArrayOut")
> Your waveform record would use DTYP="asynInt32ArrayOut".
> Mark
> ________________________________
> From: [email protected] <[email protected]> on
> behalf of [email protected] <[email protected]> Sent:
> Thursday, May 31, 2018 7:54 AM
> To: 'Jörn Dreyer'; [email protected]
> [mailto:[email protected]]
> > I'm working on a driver that needs to set 256 values into one
> > hardware register. What type of database record should I use for this purpose?
> In fact this is not so: you can write in either direction when
> processing the record, it's up to the device driver to decide whether
> to push or pull waveform data, so the waveform record will be what you need.
> This e-mail and any attachments may contain confidential, copyright
> and or privileged material, and are for the use of the intended
> addressee only. If you are not the intended addressee or an authorised
> recipient of the addressee please notify us of receipt by returning
> the e-mail and do not use, copy, retain, distribute or disclose the
> information in or attached to the e-mail. Any opinions expressed
> within this e-mail are those of the individual and not necessarily of
> Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee
> that this e-mail or any attachments are free from viruses and we
> cannot accept liability for any damage which you may sustain as a
> result of software viruses which may be transmitted in or with the
> message. Diamond Light Source Limited (company no. 4375679).
> Registered in England and Wales with its registered office at Diamond
> House, Harwell Science and Innovation Campus, Didcot, Oxfordshire,
> OX11 0DE, United Kingdom
Dr. Joern Dreyer
HIBEF DAQ + Controls
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKX                Tel: +49 351 260 3263
                                   FAX: +49 351 260 3700
01314 Dresden        eMail: [email protected]
Helmholtz-Zentrum Dresden - Rossendorf e.V (HZDR) Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Dr. h. c. Roland Sauerbrey, Dr. Ulrich Breuer
Vereinsregister: VR 1693 beim Amtsgericht Dresden
Transfering array of 256 elements to driver Jörn Dreyer
RE: Transfering array of 256 elements to driver [email protected]
Re: Transfering array of 256 elements to driver Mark Rivers
Re: Transfering array of 256 elements to driver Jörn Dreyer
Prev: Re: Transfering array of 256 elements to driver Andrew Johnson
Next: epicsmng - A tool to easily download and install epics modules Davide Marcato
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 31 May 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
