Hi Ignacio,
On 06/19/2018 09:17 AM, Ignacio Casal Iglesias wrote:
> I am trying to install MEDM on CentOS for the first time but I get an
> error on the process. I have downloaded the tar file corresponding to
> the version 3.1.11 and unzipped it in the EPICS/extensions/src
> directory. Then I do make from the extensions directory and get the
> following error:
> usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_
> -DUNIX -Dlinux -O3 -g -Wall -Wextra -mtune=generic -m64
> -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc
> -I../../../../include/os/Linux -I../../../../include
> -I../../../../../base/include/compiler/gcc
> -I../../../../../base/include/os/Linux -I../../../../../base/include
> -I../../../../include -I -MM -MF xwd2ps.d ../xwd2ps.c
> cc1: error: to generate dependencies you must specify either -M or -MM
If you look at the command line which generated that error, you can see
a '-I' option without a following include directory. Thus gcc is taking
the '-MM' to be the name of a directory to search for header files
instead of an option, which explains the error message. The issue is
that you haven't configured one of the required entries in your
extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Looking at the medm/printUtils/Makefile I suspect you need to set a
value for X11_INC.
HTH,
- Andrew
- MEDM installation Ignacio Casal Iglesias
Re: MEDM installation Mark Rivers
RE: 4k x 4k camera options? Gofron, Kazimierz
<2018>
Re: MEDM installation Ignacio Casal Iglesias
<2018>
