1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: CPP example NTTable builder
To: Heinz Junkes <[email protected]>
Cc: Talk EPICS Tech <[email protected]>
Date: Tue, 19 Jun 2018 23:02:58 -0700
On 06/19/2018 10:49 AM, Heinz Junkes wrote:
> HI,
> try to create NTTable :
>  NTTableBuilderPtr builder = NTTable::createBuilder();
>     PVStructurePtr pvStructure = builder->
>             addColumn("ts", pvInt)->
>             addColumn("X", pvDouble)->
>             addColumn("Y", pvDouble)->
>             addColumn("Z", pvDouble)->
>             addDescriptor()->
>             addAlarm()->
>             addTimeStamp()->
>             createPVStructure();
> Unfortunately, I always end up with "core-dump” on the RTEMS-system.
Are you able to test on another OS as well?
> I have not understood yet how to specify the length for the four arrays (pvInt, pvDouble [X,Y,Z] ) connected to the 4 columns.
> I thought I had to add an array structure to the 4 columns. But I found nothing in the nttable.h file how to do that.
> Every note is welcome as always.
As the reluctant maintainer of normativeTypesCPP I'm recommending not to use class NTTable.
I've not found it so helpful since, as you've found, it doesn't help with handling column data.
A more complete example, which should compile and not crash (it's late).
> #include <pv/pvData.h>
> #include <pv/standardField.h>
> namespace pvd = epics::pvData;
> static
> pvd::StructureConstPtr typedesc(pvd::getFieldCreate()->createFieldBuilder()
>                                 ->setId("epics:nt/NTTable:1.0")
>                                 ->addArray("labels", pvd::pvString)
>                                 ->addNestedStructure("value")
>                                     ->addArray("ts", pvd::pvInt)
>                                     ->addArray("X", pvd::pvDouble)
>                                     ->addArray("Y", pvd::pvDouble)
>                                     ->addArray("Z", pvd::pvDouble)
>                                 ->endNested()
>                                 //->add("timeStamp", pvd::getStandardField()->timeStamp()) // unused in this example
>                                 //->add("alarm", pvd::getStandardField()->alarm())
>                                 ->createStructure());
> pvd::PVStructure::shared_pointer buildTable(){
>     pvd::shared_vector<std::string> labels;
>     labels.push_back("The TS");
>     labels.push_back("The X");
>     labels.push_back("The Y");
>     labels.push_back("The Z");
>     pvd::shared_vector<pvd::int32> ts;
>     pvd::shared_vector<double> X, Y, Z;
>     for(size_t i=0; i<10; i++) { // some fake data
>         ts.push_back(i*10);
>         X.push_back(i);
>         Y.push_back(i+1);
>         Z.push_back(i+2);
>     pvd::PVStructure::shared_pointer value(pvd::getPVDataCreate()->createPVStructure(typedesc));
>     value->getSubFieldT<pvd::PVScalarArray>("labels")->putFrom(freeze(labels));
>     value->getSubFieldT<pvd::PVScalarArray>("value.ts")->putFrom(freeze(ts));
>     value->getSubFieldT<pvd::PVScalarArray>("value.X")->putFrom(freeze(X));
>     value->getSubFieldT<pvd::PVScalarArray>("value.Y")->putFrom(freeze(Y));
>     value->getSubFieldT<pvd::PVScalarArray>("value.Z")->putFrom(freeze(Z));
>     return value;
Re: CPP example NTTable builder Heinz Junkes
Prev: Re: EPICS Meeting Talk files Ricardo Cardenes
Next: AW: EPICS Meeting Talk files Mexner, Wolfgang (IBPT)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: CPP example NTTable builder Heinz Junkes
Next: Re: CPP example NTTable builder Heinz Junkes
ANJ, 26 Jun 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
