1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Trouble building with Visual Studio 2017
To: Tech Talk <[email protected]>
Date: Wed, 20 Jun 2018 18:31:58 +0000
I am trying a new build of EPICS, starting with base of course, on Windows.  Since I did not have the compiler on this (a virtual machine on a Mac actually) I grabbed the latest community edition which was 2017.  In the past I would make simple mods to the win32.bat in startup directory and things would work.  So far I have not found the vsvarsall.bat location in this version so I simply went to the ‘x64 Native Tools Command Prompt for VS 2017’ set the EPICS_HOST_ARCH to windows-x64 and set path to include location of make and perl and started compiling.  Everything starts OK but I reach a point where I get the following error:
cl -EHsc -GR      -DUSE_TYPED_RSET          -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include         -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp
process_begin: CreateProcess(NULL, cl -EHsc -GR -DUSE_TYPED_RSET -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/msvc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -c ../../../src/libCom/osi/os/WIN32/epicsTempFile.cpp, ...) failed.
make (e=2): The system cannot find the file specified.
make[3]: *** No rule to make target 'epicsTempFile.obj', needed by 'antelope.exe'.  Stop.
make[3]: Leaving directory 'C:/epics/base-3.16.1/src/libCom/O.windows-x64'
make[2]: *** [../../configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[2]: Leaving directory 'C:/epics/base-3.16.1/src/libCom'
make[1]: *** [../configure/RULES_DIRS:84: libCom.install] Error 2
make[1]: Leaving directory 'C:/epics/base-3.16.1/src'
make: *** [configure/RULES_DIRS:84: src.install] Error 2
make: Leaving directory 'C:/epics/base-3.16.1'
I have tried this with base-3.15.5, base-3.16.1 and base-7.0.1.1 and all stop at the same place with very similar errors (haven’t checked if they are totally identical.
Has anyone seen this problem?
John
RE: Trouble building with Visual Studio 2017 Mark Rivers
Prev: Re: R3.15 camonitor formatting Andrew Johnson
Next: Building pvData using R3.15.4 fails DPCuneo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CPP example NTTable builder Heinz Junkes
Next: RE: Trouble building with Visual Studio 2017 Mark Rivers
ANJ, 26 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
