1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: Building pvData using R3.15.4 fails
To: DPCuneo <[email protected]>
Cc: [email protected]
Date: Wed, 20 Jun 2018 13:23:42 -0700
On 06/20/2018 11:44 AM, DPCuneo wrote:
> I'm trying experiment with PVAcess while using R3.15.4, since we won't be switching to 7 very soon.
> In particular, I cloned the repo at: https://github.com/mdavidsaver/pva2pva .
Firstly, please use https://github.com/epics-base/pva2pva
> I read the README.md and set the two environment variables:
> exported EPICS_BASE and PVCOMMONS (I have EPICS4 built).
> make produces the error:
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         -MM -MF TypeFunc.d  ../../src/factory/TypeFunc.cpp
> ../../src/factory/TypeFunc.cpp:19:37: fatal error: dbDefs.h: No such file or directory
>  #include "dbDefs.h" // for NELEMENTS
> I saw another TT thread with this exact error, however it was in reference to EPICS7 and a git clone issue, rather than EPICS 3.15.x build.
This is a common error which occurs when the inter-module dependencies aren't set.
I realize I omitted this step from the README.md, which is out of date anyway.
The main documentation is at:
https://epics-base.github.io/pva2pva/
See the Building and Quick Start sections.
> The header "dbDefs.h" exists in my EPICS base in two locations:
>>find /usr/local/epics/R3.15.4/base-3.15.4 -type f -name "dbDefs.h"
> /usr/local/epics/R3.15.4/base-3.15.4/src/libCom/misc/dbDefs.h
> /usr/local/epics/R3.15.4/base-3.15.4/include/dbDefs.h
> For fun, I included "/usr/local/epics/R3.15.4/base-3.15.4/include" in the g++ call above, and just received more errors about missing headers.
> I'm new to EPICS and have limited experience with C/C++. Perhaps I'm missing something ?
Building pvData using R3.15.4 fails DPCuneo
Prev: jar file for EPICS Archive Viewer with Archive Appliance plug-in John Dobbins
Next: Re: Building pvData using R3.15.4 fails Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: Building pvData using R3.15.4 fails DPCuneo
ANJ, 20 Jun 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
