1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Why do EPICS Base startup scripts refer to non-depedencies?
To: <[email protected]>
Date: Fri, 22 Jun 2018 14:13:32 -0500
On 06/22/2018 01:12 PM, Ralph Lange wrote:
> I'd be ready to simply drop most (if not all).
> Personally I never used any of this (though I am aware that some
> portable automated builds use the script to determine the host
> architecture), and setting EPICS_HOST_ARCH is the only thing that is
> mandatory for all EPICS development and applies to all platforms.
Hmm, why don't we move the EpicsHostArch.pl script into src/tools so the
build system doesn't *need* there to be a startup directory at all and
it doesn't have to be installed.
I would still want to include some of the other files somewhere as a
starting point for site-specific scripts though. I have several
different versions of the win32.bat file for configuring Windows
development builds and IMHO something like this is pretty much essential
when developing on Windows, but I don't remember ever really using the
Site.* files (even though the last commit to them was mine, back in 2012).
> My 2 cts...
Invaluable, thanks! Unless there is other input I will work with Lewis
to implement that plan.
- Andrew
> On Fri, Jun 22, 2018 at 6:32 PM Andrew Johnson <[email protected]
> <mailto:[email protected]>> wrote:
>     Hi Lewis,
>     On 06/22/2018 10:50 AM, J. Lewis Muir wrote:
>     > Why do the scripts in the EPICS Base 3.14, 3.15, and 3.16 startup
>     > directory refer to things that are not dependencies of EPICS
>     > Base (e.g., EPICS_EXTENSIONS, PSPRINTER for some extensions,
>     > EPICS_DISPLAY_PATH and BROWSER for MEDM, ADTHOME for ADT, Exceed X11,
>     > etc.)?
>     Because they used to be managed by Janet Anderson who also handled
>     maintenance for the EPICS Extensions tree, and none of the developers
>     who are left have had the time to finish going through and cleaning them
>     all up properly since she retired.
>     I started developing code to install the contents of the startup
>     directory to $(INSTALL_LOCATION)/startup a few months back, and I also
>     did some clean-ups of the script files at the same time, but I haven't
>     had time to finish that work yet.
>     > IMO, the startup scripts should only refer to things related to EPICS
>     > Base.  For example, EPICS Base doesn't know anything about MEDM nor
>     > should it.  Therefore, <EPICS Base>/startup/Site.profile should not
>     > set EPICS_DISPLAY_PATH or anything else that relates to MEDM.  A much
>     > better way would be for the EPICS Extensions package (currently known
>     > as "Extensions build configure files") to provide a Site.profile, for
>     > example, that can be edited to provide the environment or shell
>     changes
>     > required by the different extensions.  Since MEDM, for example, is
>     > an extension, then EPICS_DISPLAY_PATH and BROWSER should be set in
>     > the Site.profile provided with the EPICS Extensions package, not the
>     > Site.profile in EPICS Base.
>     I agree with everything you wrote there. In my branch I cleaned out most
>     of Janet's commented-out settings from the win32.bat file and also added
>     a windows.bat file for windows-x64 architecture. My versions still have
>     commented-out sections for Extensions and Exceed, but I don't have any
>     problem with them being deleted as well.
>     If you want to help clean up the startup directory I would be happy to
>     work with you on this. Since these files are generally identical for all
>     release series we only need to make changes to the earliest branch
>     (currently 3.14, but without additional help the next Base-3.14.12.8
>     release will be the last one we do from that branch). Changes made to
>     3.14 will get merged up to the later branches automatically.
>     My work on installing into $(INSTALL_LOCATION)/startup was developed on
>     the 3.15 branch and I don't think I would back-port that to 3.14 because
>     it involves changes to the build rules which have evolved a bit more in
>     the 3.15 and later series, but that won't affect the work to update the
>     scripts themselves.
>     EPICS is an open source development collaboration, and we depend on our
>     users to help implement changes. I hope you will be able to find some
>     time to contribute.
>     Thanks,
>     - Andrew
>     Arguing for surveillance because you have nothing to hide is no
>     different than making the claim, "I don't care about freedom of
>     speech because I have nothing to say." -- Edward Snowdon
Why do EPICS Base startup scripts refer to non-depedencies? J. Lewis Muir
Re: Why do EPICS Base startup scripts refer to non-depedencies? Andrew Johnson
Re: Why do EPICS Base startup scripts refer to non-depedencies? Ralph Lange
Prev: Re: Why do EPICS Base startup scripts refer to non-depedencies? Ralph Lange
Next: Re: A recent R3.15.5 Patch file Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: compilation error on pvData wrt epics base Jeong Han Lee
ANJ, 23 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
