Hi Andrew,
My BASE is in the following location:
$ tree -L 1 /epics/base-3.16.1/
/epics/base-3.16.1/
├── [root 4.0K] bin
├── [root 4.0K] configure
├── [root 4.0K] db
├── [root 4.0K] dbd
├── [root 4.0K] html
├── [root 12K] include
├── [root 4.0K] lib
├── [root 4.0K] startup
└── [root 4.0K] templates
And I added the RELEASE.local in pvDataCPP/configure with
EPICS_BASE=/epics/base-3.16.1/
I am using base-3.15.5 and 3.16.1, I don't need EPICS_LIBCOM variable
in RELEASE, so I add only EPICS_BASE. That is only what I add into
pvDataCPP.
Do I miss something?
Best,
Han
On 06/23/2018 07:22 PM, Johnson, Andrew N. wrote:
Hi Han
When you wrote “install pvData (in source directory)” what did you mean, and did you edit the pvData/configure/RELEASE file? I suspect you are not configuring the pvData module correctly.
Unless you’re using EPICS 7 or the fully bundled 4.7 release you need to treat each of the PVA modules as a regular support module, installing them in their own area and editing the configure/RELEASE files as appropriate (there should be comments in each file explaining what other modules they need to point to). It is also possible to set a value for INSTALL_LOCATION to a common directory in the modules’ CONFIG_SITE file, in which case you don’t have to worry about editing the RELEASE files.
- Andrew
- compilation error on pvData wrt epics base Jeong Han Lee
- Re: compilation error on pvData wrt epics base Johnson, Andrew N.
pvData internal version doesn't match with "release tag" Jeong Han Lee
<2018>
<2018>
