1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ADLambda compilaiton of vendor sources (LambdaSupport)
To: "Gofron, Kazimierz" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Jul 2018 12:52:24 +0000
Hi Kaz,
I have not worked on the ADLambda driver.  But generally when I have the source code to a vendor library I modify it to build with the EPICS build system.  That is what I have done for dxp, dxpSITORO, all of the libraries in ADSupport, etc.  It's a bit more work, but allows it to build in environments that the vendor may not directly support.
Sent: Wednesday, July 4, 2018 11:27 PM
To: [email protected]
Cc: Mark Rivers
Subject: ADLambda compilaiton of vendor sources (LambdaSupport)
I am not able to compile vendor sources for ADLambda detector, cloned from the github.com/areaDetector/ADLambda. Perhaps someone has done it successfully.
System: Debian 9, Debian 8
EPICS base: base-7.0.1.1
AreaDetector: R3-3-1 (master from today)
I am following the compilation instructions written in LambdaSupport/liblambda/INSTALL
1.       Created liblambda-build             {build directory for cmake}
2.       Created liblambda-linux-x86_64 {install directory}
kaz@stretch64:/epics/support/areaDetector-3-3/ADLambda/LambdaSupport$ ls -l
total 28
-rw-r--r-- 1 kaz kaz  634 Jul  4 23:05 INSTALL-EPICS
drwxr-xr-x 5 kaz kaz 4096 Jul  4 23:05 libcommon
drwxr-xr-x 6 kaz kaz 4096 Jul  4 23:05 liblambda
drwxr-xr-x 5 kaz kaz 4096 Jul  5 00:12 liblambda-build
drwxr-xr-x 2 kaz kaz 4096 Jul  5 00:10 liblambda-linux-x86_64
-rw-r--r-- 1 kaz kaz  739 Jul  4 23:05 Makefile
-rw-r--r-- 1 kaz kaz 1146 Jul  4 23:05 README
kaz@stretch64:/epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda-build$ cmake -DCMAKE_INSTALL_PREFIX=../liblambda-linux-x86_64 ../liblambda
-- The C compiler identification is GNU 6.3.0
-- The CXX compiler identification is GNU 6.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- path is:/epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda/cmake/
CMake Warning at CMakeLists.txt:15 (find_package):
  By not providing "FindLibCommon.cmake" in CMAKE_MODULE_PATH this project
  has asked CMake to find a package configuration file provided by
  "LibCommon", but CMake did not find one.
  Could not find a package configuration file provided by "LibCommon" with
  any of the following names:
    LibCommonConfig.cmake
    libcommon-config.cmake
  Add the installation prefix of "LibCommon" to CMAKE_PREFIX_PATH or set
  "LibCommon_DIR" to a directory containing one of the above files.  If
  "LibCommon" provides a separate development package or SDK, be sure it has
  been installed.
CMake Warning at CMakeLists.txt:16 (find_package):
  By not providing "FindLibBoost.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "LibBoost",
  Could not find a package configuration file provided by "LibBoost" with any
    LibBoostConfig.cmake
    libboost-config.cmake
  Add the installation prefix of "LibBoost" to CMAKE_PREFIX_PATH or set
  "LibBoost_DIR" to a directory containing one of the above files.  If
  "LibBoost" provides a separate development package or SDK, be sure it has
  been installed.
CMake Warning at CMakeLists.txt:17 (find_package):
  By not providing "FindZlib.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Zlib", but
  Could not find a package configuration file provided by "Zlib" with any of
    ZlibConfig.cmake
    zlib-config.cmake
  Add the installation prefix of "Zlib" to CMAKE_PREFIX_PATH or set
  "Zlib_DIR" to a directory containing one of the above files.  If "Zlib"
  provides a separate development package or SDK, be sure it has been
  installed.
-- Install directory is: /epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda-linux-x86_64
-- No build type selected, default to RELEASE
-- Build type: RELEASE
-- Configuring done
-- Generating done
-- Build files have been written to: /epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda-build
kaz@stretch64:/epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda-build$ ls
CMakeCache.txt  CMakeFiles  cmake_install.cmake  include  Makefile  src
kaz@stretch64:/epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda-build$ make
Scanning dependencies of target lambda
[ 11%] Building CXX object src/CMakeFiles/lambda.dir/ImageDecoder.cpp.o
In file included from /epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda/include/ImageDecoder.h:25:0,
                 from /epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda/src/ImageDecoder.cpp:22:
/epics/support/areaDetector-3-3/ADLambda/LambdaSupport/liblambda/include/LambdaGlobals.h:25:21: fatal error: Globals.h: No such file or directory
#include "Globals.h"
compilation terminated.
src/CMakeFiles/lambda.dir/build.make:62: recipe for target 'src/CMakeFiles/lambda.dir/ImageDecoder.cpp.o' failed
make[2]: *** [src/CMakeFiles/lambda.dir/ImageDecoder.cpp.o] Error 1
CMakeFiles/Makefile2:103: recipe for target 'src/CMakeFiles/lambda.dir/all' failed
make[1]: *** [src/CMakeFiles/lambda.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
Kazimierz Gofron
NSLS-II Controls Group
Brookhaven National Laboratory
(p) +1 (631) 344 5283
(f) +1 (631) 344 8085
(e) [email protected]<mailto:[email protected]>
(w) www.bnl.gov/nsls2<http://www.bnl.gov/nsls2>
ADLambda compilaiton of vendor sources (LambdaSupport) Gofron, Kazimierz
Prev: PMAC Gather Hidas, Dean
Next: Re: Building latest AreaDetector from the synApps collection Lang, Keenan C.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ADLambda compilaiton of vendor sources (LambdaSupport) Gofron, Kazimierz
Next: PMAC Gather Hidas, Dean
ANJ, 05 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
