1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is EPICS license GPL-compatible?
To: [email protected]
Date: Mon, 09 Jul 2018 12:48:10 +0200
Disclaimer: I am not a lawyer and this is not legal advice. Also, I am not an
EPICS developer
That said, by reading the EOL I do not find any reason to believe it not being
GPL-compatible.
In fact, the only part that I had my doubts with was EOL's section 4c, but
doing a bit of research, I found that it is equivalent to similar clauses in
other officially GPL-compatible licenses [1] (see e.g. clause 4b of the
Apache2.0 license [2]).
In any case, I think it would be nice to actually submit the question to [3]
Cheers,
Carlos
[1] https://www.gnu.org/licenses/gpl-faq.en.htm
[2] http://directory.fsf.org/wiki/License:Apache2.0
[3] [email protected]
On Sunday, July 8, 2018 8:31:08 PM CEST Johnson, Andrew N. wrote:
> Hi Gabriel,
> Disclaimer: I am not a lawyer, and this is not legal advice.
> Most EPICS software is distributed as source code, rarely as binaries (there
> are binary packages available for Debian Linux but they should have source
> packages available too, and I’m not really talking about them here). The
> EPICS Open License (EOL) does permit binary distribution with certain
> conditions though, so some companies sell products including binary
> versions of the EPICS core code and this is legally fine as long as they
> follow those conditions.
> The question of compatibility between the EOL and the GPL isn’t something we
> have asked for legal advice over, but I don’t personally have any
> objections to projects using the GPL, and I think that would be true for
> all of the current core developers. If there is a legal incompatibility the
> act of distributing as source code instead of binaries would also prevent
> problems, because the end-user is the one combining the code and the GPL
> conditions are only triggered by the act of distribution.
> I hope this helps, but I don’t think anyone could give you a definitive
> answer.
> - Andrew
> Sent from my iPad
> > On Jul 6, 2018, at 7:38 AM, Gabriel de Souza Fedel <[email protected]>
> > wrote:
> > Hi,
> > Someone knows if is it possible (legal) create a project using epics and
> > share this project with GPL license?
> > I found an old post (from 2001) saying that is not possible, but I found
> > some projects using EPICS and with GPL license.
> > Thank you,
> > Regards
> > Gabriel Fedel
> > Software de Operação das Linhas de Luz
> > Laboratório Nacional de Luz Síncrotron – (LNLS)
> > Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
> > [email protected] | +55 (19) 3512 1226
> > www.lnls.cnpem.br
 Carlos Pascual Izarra
 Scientific Software Coordinator
 Computing Division
 ALBA Synchrotron  [http://www.albasynchrotron.es]
 Carrer de la Llum 2-26
 E-08290 Cerdanyola del Valles (Barcelona), Spain
 E-mail: [email protected]
 Phone: +34 93 592 4428
Re: Is EPICS license GPL-compatible? Gabriel de Souza Fedel
Re: Is EPICS license GPL-compatible? Johnson, Andrew N.
Prev: Re: Delta Tau Power Brick LV-IMS driver [email protected]
Next: Failed caput not notified when using ca_array_put_callback [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Is EPICS license GPL-compatible? Johnson, Andrew N.
Next: Re: Is EPICS license GPL-compatible? Gabriel de Souza Fedel
ANJ, 11 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
