Here is a very curious issue that I've just stumbled across: asynchronous caput failure is reported, synchronous caput failure is hidden.
I have a PV that (depending on the state of the IOC) is rejecting caputs; it does this by returning 1 from the appropriate record processing function. Using the command line caput tool I observe a strange discrepancy, watch:
1. asynchronous put
$ caput TS-DI-TMBF-02:MEM:CAPTURE_S 0
Old : TS-DI-TMBF-02:MEM:CAPTURE_S
CA.Client.Exception...............................................
Warning: "Channel write request failed"
Context: "op=1, channel=TS-DI-TMBF-02:MEM:CAPTURE_S, type=DBR_DOUBLE, count=1, ctx="TS-DI-TMBF-02:MEM:CAPTURE_S""
Source File: ../oldChannelNotify.cpp line 159
New : TS-DI-TMBF-02:MEM:CAPTURE_S
Current Time: Mon Jul 09 2018 14:14:03.307001699
2. synchronous put
$ caput -c -w 1 TS-DI-TMBF-02:MEM:CAPTURE_S 0
Note that in case (1) we have asynchronous notification of the put failure ... which I presume we get to see because caput follows up with a caget giving time for the failure to be returned.
On the other hand, in case (2) no error is reported.
Repeating this test with other tools, it seems that the callback called by ca_array_put_callback is always called with args.status == ECA_NORMAL, and I can see no other channel for notifying failure.
This is odd, and I'm surprised to have stumbled across this after so many years. I'm sure this is a defect somewhere, but am afraid I can't see on which side of the wire it sits.
- RE: Failed caput not notified when using ca_array_put_callback [email protected]
Re: Is EPICS license GPL-compatible? Carlos Pascual
RE: 'assert (pca->pgetNative)' failed in ../dbCa.c [email protected]
<2018>
New release of ADProsilica Mark Rivers
<2018>
