1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Network errors on a 6100 (running RTEMS 4.10.2)
To: Talk EPICS Tech <[email protected]>
Date: Mon, 9 Jul 2018 16:01:12 -1000
I got a 6100 that was booting correctly, but then refusing to mount the file system over NFS (and complaining also about NTP).
If found an old message that matched my problem, and an answer suggesting to force the speed in the switch (down to 100Mbps) instead of letting the board auto-negotiate it. Till Straumann replied that this should not be necessary, as those boards are known to be working properly with Gigabit Ethernet, but this actually worked for me (!!)
Has anyone else experienced the same problem? Any hints/solutions?
Cheers,
Ricardo
RE: Network errors on a 6100 (running RTEMS 4.10.2) Mark Engbretson
Prev: areaDetector R3-3-2 released Mark Rivers
Next: RE: Failed caput not notified when using ca_array_put_callback [email protected]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Network errors on a 6100 (running RTEMS 4.10.2) Mark Engbretson
ANJ, 10 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
