1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM compilation on Ubuntu 16.04
To: Alper Kinaci <[email protected]>, "[email protected]" <[email protected]>
Cc: Sumit Kewalramani <[email protected]>
Date: Wed, 18 Jul 2018 16:02:06 +0000
This message suggests that packages for earlier versions of Ubuntu may work.
https://askubuntu.com/questions/944838/libxp-so-6-missing-for-ubuntu-17-04
From: [email protected] <[email protected]> on behalf of Alper Kinaci <[email protected]>
Sent: Tuesday, July 10, 2018 5:37 PM
To: [email protected]
Subject: MEDM compilation on Ubuntu 16.04
Dear Developers,
I am trying to build MEDM on our Epics (base-3.15.5) and areaDetector (specifically ADEiger) installations on an Ubuntu 16.04 machine. I followed the instructions on "https://epics.anl.gov/extensions/medm/"; webpage however one of the packages needed for MEDM, i.e. libxp-dev (and also libxp), is not available for this version of Ubuntu.
I can find the library deb file (libxp-dev_1.0.2-1ubuntu1_amd64.deb) for Ubuntu 14.04 however I am not sure if this package will work with our operating system.
If I comment out the line "USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext" and uncomment "USR_LIBS_Linux = Xm Xt Xmu X11 Xext" to remove libXp linkage in medm Makefile, the compilation still fails due to some undefined references to functions. That reminds me the errors I receive when some header files are missing. I included the error lines in my compilation at the end.
I will appreciate any guidance or hint on this issue. Thank you for your consideration.
Best regards,
Alper
Alper Kinaci, PhD
Sr Computational Specialist
Research Computing Services
Information Technology
Northwestern University
[email protected]
847.467.7615
/usr/bin/g++ -o medm -Wl,-Bstatic -L/home/epics-admin/Documents/areaDetector/lib/linux-x86_64 -L/home/epics-admin/Documents/base-3.15.5/lib/linux-x86_64 -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/home/epics-admin/Documents/areaDetector/lib/linux-x86_64 -Wl,-rpath,/home/epics-admin/Documents/base-3.15.5/lib/linux-x86_64 -Wl,-rpath,/usr/lib/x86_64-linux-gnu           -rdynamic -m64             medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o productDescriptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o xgif.o   -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXmu -lX11 -lXext -Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/lib/x86_64-linux-gnu/libXm.a(Label.o): In function `Redisplay':
(.text+0xef8): undefined reference to `XftDrawSetClip'
/usr/lib/x86_64-linux-gnu/libXm.a(LabelG.o): In function `_XmRedisplayLabG':
(.text+0x3543): undefined reference to `XftDrawSetClip'
/usr/lib/x86_64-linux-gnu/libXm.a(TextIn.o): In function `SelfInsert':
(.text+0x6cf3): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextOut.o): In function `FindWidth':
(.text+0x190e): undefined reference to `XftTextExtentsUtf8'
(.text+0x19d3): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextOut.o): In function `FindHeight':
(.text+0x221c): undefined reference to `XftTextExtentsUtf8'
(.text+0x22f5): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(XmString.o):(.text+0x6d1): more undefined references to `XftTextExtentsUtf8' follow
/usr/lib/x86_64-linux-gnu/libXm.a(XmString.o): In function `SubStringPosition':
(.text+0xc1af): undefined reference to `XftTextExtents16'
(.text+0xc243): undefined reference to `XftTextExtents16'
/usr/lib/x86_64-linux-gnu/libXm.a(XmString.o): In function `_render':
(.text+0xe2c5): undefined reference to `XftDrawSetClip'
/usr/lib/x86_64-linux-gnu/libXm.a(TextF.o): In function `FindPixelLength.part.6':
(.text+0x1dbe): undefined reference to `XftTextExtentsUtf8'
(.text+0x1f15): undefined reference to `XftTextExtentsUtf8'
(.text+0x1fa5): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextF.o): In function `PrintableString':
(.text+0x27ae): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(TextF.o): In function `TextFieldResetIC':
(.text+0x8522): undefined reference to `XftTextExtentsUtf8'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `FreeRendition':
(.text+0x10aa): undefined reference to `XftFontClose'
(.text+0x10cc): undefined reference to `FcPatternDestroy'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `ValidateAndLoadFont':
(.text+0x1d1f): undefined reference to `FcPatternCreate'
(.text+0x1d45): undefined reference to `FcPatternAddString'
(.text+0x1d63): undefined reference to `FcPatternAddString'
(.text+0x1d81): undefined reference to `FcPatternAddString'
(.text+0x1d9f): undefined reference to `FcPatternAddString'
(.text+0x1e01): undefined reference to `XftFontMatch'
(.text+0x1e12): undefined reference to `XftFontOpenPattern'
(.text+0x20c5): undefined reference to `FcPatternAddInteger'
(.text+0x20df): undefined reference to `FcPatternAddInteger'
(.text+0x20f9): undefined reference to `FcPatternAddInteger'
(.text+0x2113): undefined reference to `FcPatternAddInteger'
(.text+0x212d): undefined reference to `FcPatternAddInteger'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawCreate':
(.text+0x4b69): undefined reference to `XftDrawCreate'
(.text+0x4c42): undefined reference to `XftDrawCreateBitmap'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawString2':
(.text+0x4df7): undefined reference to `XftDrawStringUtf8'
(.text+0x4e1f): undefined reference to `XftDrawString32'
(.text+0x4e4f): undefined reference to `XftDrawString16'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawString':
(.text+0x4f44): undefined reference to `XftDrawRect'
(.text+0x4fd6): undefined reference to `XftDrawStringUtf8'
(.text+0x500e): undefined reference to `XftDrawString32'
(.text+0x504e): undefined reference to `XftDrawString16'
(.text+0x507c): undefined reference to `XftTextExtents16'
(.text+0x50ac): undefined reference to `XftTextExtentsUtf8'
(.text+0x515c): undefined reference to `XftTextExtents32'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftFontAverageWidth':
(.text+0x5285): undefined reference to `XftTextExtents8'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftDrawDestroy':
(.text+0x4c9f): undefined reference to `XftDrawDestroy'
/usr/lib/x86_64-linux-gnu/libXm.a(XmRenderT.o): In function `_XmXftSetClipRectangles':
(.text+0x5233): undefined reference to `XftDrawSetClipRectangles'
/usr/lib/x86_64-linux-gnu/libXm.a(Jpeg.o): In function `load_jpeg':
(.text+0x6c): undefined reference to `jpeg_std_error'
(.text+0x9d): undefined reference to `jpeg_destroy_decompress'
(.text+0xdb): undefined reference to `jpeg_CreateDecompress'
(.text+0xed): undefined reference to `jpeg_stdio_src'
(.text+0xff): undefined reference to `jpeg_read_header'
(.text+0x10c): undefined reference to `jpeg_calc_output_dimensions'
(.text+0x119): undefined reference to `jpeg_start_decompress'
(.text+0x17e): undefined reference to `jpeg_read_scanlines'
(.text+0x1b5): undefined reference to `jpeg_finish_decompress'
(.text+0x1c2): undefined reference to `jpeg_destroy_decompress'
/usr/lib/x86_64-linux-gnu/libXm.a(Png.o): In function `png_load_file.constprop.0':
(.text+0x7a): undefined reference to `png_sig_cmp'
(.text+0xbc): undefined reference to `png_create_read_struct'
(.text+0xce): undefined reference to `png_create_info_struct'
(.text+0x102): undefined reference to `png_destroy_read_struct'
(.text+0x118): undefined reference to `png_destroy_read_struct'
(.text+0x14b): undefined reference to `png_init_io'
(.text+0x15a): undefined reference to `png_set_sig_bytes'
(.text+0x169): undefined reference to `png_read_info'
(.text+0x199): undefined reference to `png_get_IHDR'
(.text+0x1f1): undefined reference to `png_get_valid'
(.text+0x219): undefined reference to `png_set_gray_to_rgb'
(.text+0x22d): undefined reference to `png_get_gAMA'
(.text+0x245): undefined reference to `png_read_update_info'
(.text+0x254): undefined reference to `png_get_rowbytes'
(.text+0x26e): undefined reference to `png_get_channels'
(.text+0x2e8): undefined reference to `png_read_image'
(.text+0x2fc): undefined reference to `png_read_end'
(.text+0x325): undefined reference to `png_destroy_read_struct'
(.text+0x369): undefined reference to `png_set_gamma'
(.text+0x37e): undefined reference to `png_set_expand'
(.text+0x39a): undefined reference to `png_destroy_read_struct'
(.text+0x3ae): undefined reference to `png_set_expand'
(.text+0x3cd): undefined reference to `png_destroy_read_struct'
(.text+0x3e6): undefined reference to `png_set_strip_16'
(.text+0x3f6): undefined reference to `png_set_expand'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `SetSessionProperties':
(.text+0x2158): undefined reference to `SmcSetProperties'
(.text+0x221d): undefined reference to `SmcSetProperties'
(.text+0x22ab): undefined reference to `SmcDeleteProperties'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `XtInteractPermission':
(.text+0x346b): undefined reference to `SmcInteractDone'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `StopManagingSession.isra.10':
(.text+0x3499): undefined reference to `SmcCloseConnection'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `GetIceEvent':
(.text+0x35ac): undefined reference to `SmcGetIceConnection'
(.text+0x35b8): undefined reference to `IceProcessMessages'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `JoinSession':
(.text+0x3864): undefined reference to `SmcModifyCallbacks'
(.text+0x3870): undefined reference to `SmcClientID'
(.text+0x38c1): undefined reference to `SmcGetIceConnection'
(.text+0x38c9): undefined reference to `IceConnectionNumber'
(.text+0x3a29): undefined reference to `SmcOpenConnection'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `XtSessionReturnToken':
(.text+0x4792): undefined reference to `SmcInteractDone'
(.text+0x47ce): undefined reference to `SmcInteractRequest'
(.text+0x4847): undefined reference to `SmcSaveYourselfDone'
(.text+0x4880): undefined reference to `SmcRequestSaveYourselfPhase2'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `CallSaveCallbacks':
(.text+0x48b2): undefined reference to `SmcSaveYourselfDone'
/usr/lib/x86_64-linux-gnu/libXt.a(Shell.o): In function `XtCallCancelCallbacks':
(.text+0x49fb): undefined reference to `SmcSaveYourselfDone'
/usr/lib/x86_64-linux-gnu/libX11.a(ClDisplay.o): In function `XCloseDisplay':
(.text+0xd3): undefined reference to `xcb_disconnect'
/usr/lib/x86_64-linux-gnu/libX11.a(OpenDis.o): In function `OutOfMemory':
(.text+0x444): undefined reference to `xcb_disconnect'
/usr/lib/x86_64-linux-gnu/libX11.a(OpenDis.o): In function `XOpenDisplay':
(.text+0x87c): undefined reference to `xcb_get_setup'
(.text+0xe36): undefined reference to `xcb_get_maximum_request_length'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_disp.o): In function `_XConnectXCB':
(.text+0x14c): undefined reference to `xcb_parse_display'
(.text+0x1be): undefined reference to `xcb_connect_to_display_with_auth_info'
(.text+0x1de): undefined reference to `xcb_get_file_descriptor'
(.text+0x1fb): undefined reference to `xcb_generate_id'
(.text+0x26e): undefined reference to `xcb_connection_has_error'
(.text+0x286): undefined reference to `xcb_connect'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `require_socket':
(.text+0x6a3): undefined reference to `xcb_take_socket'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `poll_for_event':
(.text+0x824): undefined reference to `xcb_poll_for_event'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `poll_for_response':
(.text+0x920): undefined reference to `xcb_poll_for_reply'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XSend':
(.text+0xbb2): undefined reference to `xcb_writev'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XEventsQueued':
(.text+0xc7d): undefined reference to `xcb_connection_has_error'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XReadEvents':
(.text+0xd9a): undefined reference to `xcb_connection_has_error'
(.text+0xe34): undefined reference to `xcb_wait_for_event'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XAllocIDs':
(.text+0xfaf): undefined reference to `xcb_generate_id'
/usr/lib/x86_64-linux-gnu/libX11.a(xcb_io.o): In function `_XReply':
(.text+0x113d): undefined reference to `xcb_wait_for_reply'
collect2: error: ld returned 1 exit status
/home/epics-admin/Documents/base-3.15.5/configure/RULES_BUILD:201: recipe for target 'medm' failed
make[2]: *** [medm] Error 1
make[2]: Leaving directory '/home/epics-admin/Documents/areaDetector/epics-extensions/medm/medm/O.linux-x86_64'
/home/epics-admin/Documents/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/epics-admin/Documents/areaDetector/epics-extensions/medm/medm'
/home/epics-admin/Documents/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
MEDM compilation on Ubuntu 16.04 Alper Kinaci
Prev: Re: Rotating Image in NDPluginPva plugin Mark Rivers
Next: Re: MEDM compilation on Ubuntu 16.04 Bob Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MEDM compilation on Ubuntu 16.04 Alper Kinaci
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
