1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Rotating Image in NDPluginPva plugin
To: "Rivers, Mark L." <[email protected]>, "J. Lewis Muir" <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Wed, 18 Jul 2018 16:07:57 +0000
Hi Mark, Lewis,
I rotated the image 90 deg with NDPluginTransform.
But I did not see any change in ImageJ.
Did I miss anything?
Guobao
On 7/18/18, 10:35 AM, "Mark Rivers" <[email protected]> wrote:
    Hi Guobao,
    Lewis is correct.  The NDPluginPva has never had rotation capability, you should use the NDPluginTransform for that.
    From: [email protected] <[email protected]> on behalf of J. Lewis Muir <[email protected]>
    Sent: Wednesday, July 18, 2018 10:18 AM
    To: Shen, Guobao
    Cc: Tech-Talk
    On 07/18, Shen, Guobao wrote:
    > Hi,
    > I found there was an old discussion to rotate image by 90 degree (or 270 degree) in areaDetector NDPluginPva plugin,
    > https://epics.anl.gov/tech-talk/2017/msg00454.php
    > Is that function available to use now?
    > Thanks,
    > Guobao
    Can't you use NDPluginTransform to rotate, and then feed that to
    NDPluginPva?
    Lewis
Re: Rotating Image in NDPluginPva plugin Mark Rivers
Rotating Image in NDPluginPva plugin Shen, Guobao
Re: Rotating Image in NDPluginPva plugin J. Lewis Muir
Prev: Re: MEDM compilation on Ubuntu 16.04 Bob Soliday
Next: Re: MEDM compilation on Ubuntu 16.04 Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Rotating Image in NDPluginPva plugin Mark Rivers
Next: Re: Rotating Image in NDPluginPva plugin Mark Rivers
ANJ, 18 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
