You need to tell the NDPluginPva to get its array from the NDPluginTransform, rather than directly from the detector. This is the ArrayPort PV.
Sent: Wednesday, July 18, 2018 11:07 AM
To: Mark Rivers; J. Lewis Muir
Cc: Tech-Talk
Subject: Re: Rotating Image in NDPluginPva plugin
Hi Mark, Lewis,
I rotated the image 90 deg with NDPluginTransform.
But I did not see any change in ImageJ.
Did I miss anything?
Guobao
?On 7/18/18, 10:35 AM, "Mark Rivers" <[email protected]> wrote:
Hi Guobao,
Lewis is correct. The NDPluginPva has never had rotation capability, you should use the NDPluginTransform for that.
From: [email protected] <[email protected]> on behalf of J. Lewis Muir <[email protected]>
Sent: Wednesday, July 18, 2018 10:18 AM
To: Shen, Guobao
Cc: Tech-Talk
On 07/18, Shen, Guobao wrote:
> Hi,
> I found there was an old discussion to rotate image by 90 degree (or 270 degree) in areaDetector NDPluginPva plugin,
> https://epics.anl.gov/tech-talk/2017/msg00454.php
> Is that function available to use now?
> Thanks,
> Guobao
Can't you use NDPluginTransform to rotate, and then feed that to
NDPluginPva?
Lewis
- Re: Rotating Image in NDPluginPva plugin Shen, Guobao
- Rotating Image in NDPluginPva plugin Shen, Guobao
- Re: Rotating Image in NDPluginPva plugin J. Lewis Muir
- Re: Rotating Image in NDPluginPva plugin Mark Rivers
Re: MEDM compilation on Ubuntu 16.04 Jeong Han Lee
Re: MEDM compilation on Ubuntu 16.04 Bob Soliday
<2018>
<2018>
