1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: a question for msi
To: <[email protected]>
Date: Tue, 31 Jul 2018 17:04:26 -0700
I'd be in favor of removing them unless the -V flag was set.
Most of our msi use is intended to be loaded w/ macro definitions in our st.cmd
file, so it's just annoying to see ",undefined" in files we've built up from templates
when we know we'll define those macros later.
We set the -V flag only for those few msi uses where the files need to have
all macros expanded.   For those cases it would still be helpful to see
the ",undefined" or ",recursive" warning text in the msi output file as we do now.
Cheers,
- Bruce
On 07/31/2018 02:57 PM, Andrew Johnson wrote:
If there is a consensus that they are not useful I have a modification
that removes the ",undefined" error indicator from the output generated
by macLib (and hence the output from msi as long as the -V flag is used)
when it encounters a $(macro) that it doesn't have a value for. There is
also a ",recursive" marker for macros that are defined in a substitution
file using themselves.
As Bruce said, these markers don't change how a file is interpreted by
an IOC when they are present, but if you feed the output into some other
tool that doesn't understand them they might be annoying.
Please discuss here if you particularly like or dislike these markers.
- Andrew
On 07/30/2018 04:23 PM, Jeong Han Lee wrote:
   Is there any other way to suppress or omit (,undefined) in the output
file by using MSI?
   Han
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Re: a question for msi Jeong Han Lee
Re: a question for msi Andrew Johnson
Prev: Re: a question for msi Andrew Johnson
Next: Re: a question for msi Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
