Hi Bruce and Andrew,
My intention isn't in EPICS IOC DB, I would like to use msi to handle
many configuration files instead of m4 in specifically ESS EPICS
building environment and my own EPICS building environment as well. I
would like to stay within existent epics applications as much as possible.
I didn't look at its source codes, but it's better to have a flag to
turn ".undefined" or ",recursive" warning texts.
However, you can simply ignore my question if you don't have any
resources. Maybe I can spend some time later to implement this feature
by myself.
Thanks for everything!
Han
On 08/01/2018 02:04 AM, Bruce Hill wrote:
I'd be in favor of removing them unless the -V flag was set.
Most of our msi use is intended to be loaded w/ macro definitions in our
st.cmd
file, so it's just annoying to see ",undefined" in files we've built up
from templates
when we know we'll define those macros later.
We set the -V flag only for those few msi uses where the files need to have
all macros expanded. For those cases it would still be helpful to see
the ",undefined" or ",recursive" warning text in the msi output file as
we do now.
Cheers,
- Bruce
On 07/31/2018 02:57 PM, Andrew Johnson wrote:
If there is a consensus that they are not useful I have a modification
that removes the ",undefined" error indicator from the output generated
by macLib (and hence the output from msi as long as the -V flag is used)
when it encounters a $(macro) that it doesn't have a value for. There is
also a ",recursive" marker for macros that are defined in a substitution
file using themselves.
As Bruce said, these markers don't change how a file is interpreted by
an IOC when they are present, but if you feed the output into some other
tool that doesn't understand them they might be annoying.
Please discuss here if you particularly like or dislike these markers.
- Andrew
On 07/30/2018 04:23 PM, Jeong Han Lee wrote:
Is there any other way to suppress or omit (,undefined) in the output
file by using MSI?
Han
- Re: a question for msi Andrew Johnson
- a question for msi Jeong Han Lee
- Re: a question for msi Bruce Hill
Personal EPICS Building Environment Jeong Han Lee
<2018>
<2018>
ANJ, 10 Aug 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
