1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Parse a variable-length, multi-column waveform in stream device
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Aug 2018 11:36:40 +0200
Hello Ahmad,
StreamDevice can read variable length arrays. You need to set NELM to the maximum number of elements. StreamDevice will set NORD to the number of elements found. Modern EPICS versions are able to handle variable length arrays when the client sets up a monitor using 0 for the requested array length. It should then use the current NORD value.
However StreamDevice reads arrays in rows, not columns. If you have a waveform record and use { separator=" "; in "%i"; }, stream device will repeat the "%i" up to NELM times (or until end of line, until the separator is not found any more or until the conversion fails).
But in your case it seems you have interlaced arrays:
a[0] b[0] c[0] d[0] e[0] f[0] g[0] h[0]
a[1] b[1] c[1] d[1] e[1] f[1] g[1] h[1]
a[2] b[2] c[2] d[2] e[2] f[2] g[2] h[2]
So StreamDevice will see the first elements of each array, not all elements of one array.
StreamDevice would be able to read rows with variable length:
a[0] a[1] a[2] ...
b[0] b[1] b[2] ...
c[0] c[1] c[2] ...
d[0] d[1] d[2] ...
e[0] e[1] e[2] ...
f[0] f[1] f[2] ...
g[0] g[1] g[2] ...
h[0] h[1] h[2] ...
Also this will not help:
in "%i %*i %*i %*i %*i %*i %*i %*i";
Because the first %i reads all the elements in the row before even parsing the first %*i.
I need a new syntax to specify interlaces arrays.
The only way I can think to at the moment is to pre-process the input with a regsub which removed the "other" array elements from the input, but I need to test that first. It may be quite inefficient. Thus if <N> becomes huge (say >1000) parsing may be quite slow.
I will tell you soon if I can find a solution...
Dirk
On 08.08.2018 11:09, Abdalla  Ahmad wrote:
Hi
We are trying to implement an IOC for the Libera Spark BPM using stream device, one of the tricky commands for example is TBT_IQ <N> which returns a variable-length buffer of turn-by-turn data. An example:
TBT_IQ 3
22 -36  19 -38  16 -31  -3  -31
39 -212 29 -212 26 -163 -37 -150
39 -175 36 -176 27 -133 -21 -129
As you can see the output is an array of fixed columns (IQ parameters) and variable rows (waveforms length). In a single line you can easily parse and skip any value, but in this format we have two problems:
1.Is it possible to parse variable number of IN commands in the protocol file?
2.Variable "IN" commands mean variable waveform length, is this possible in EPICS?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo <http://www.sesame.org.jo/>
RE: Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
Prev: Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
Next: Re: IOC Crash with No Exception Generated Ricardo Cardenes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Parse a variable-length, multi-column waveform in stream device Abdalla Ahmad
ANJ, 12 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
