1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM X/Y Plot segfaults
To: "Sinclair, John William" <[email protected]>, Bruce Hill <[email protected]>, Christoph Schroeder <[email protected]>, "[email protected]" <[email protected]>, "Baily, Scott A" <[email protected]>
Date: Tue, 21 Aug 2018 16:11:02 -0500
Hi John,
On 08/21/2018 03:37 PM, Sinclair, John William wrote:
> When I say that edm is single threaded, I mean there should never be
> contention for resources among multiple threads.
> Edm calls ca_context_create( ca_disable_preemptive_callback );
> I believe that forces callbacks to always occur in the thread in which
> the callback was requested.
That isn't quite the case, but it's close and should be sufficient as
long as no other code is thread-aware or using thread-local variables.
What it actually does is ensure that the main thread is inside a call to
ca_pend_event() or ca_pend_io() before calling the callbacks, but those
callbacks do occur (one at a time, never simultaneously) from other CA
threads though (using a different thread for each IOC or CA server the
library is connected to). The main thread will never return to the
application code until all callbacks in the other threads have returned.
This prevents race conditions between the main thread and the callbacks
because CA handles all of the synchronization that is needed for a
"thread-naive" application.
The situation may be slightly different if the application's callback
routines make calls into a library that is itself thread-aware and/or
uses thread-local variables internally — any thread-local variables
might not have been properly initialized for the CA's per-IOC threads.
The symptoms described don't seem to imply that's the problem here, but
I can't guarantee it.
- Andrew
EDM X/Y Plot segfaults Eric Norum
Re: EDM X/Y Plot segfaults Eric Norum
Re: EDM X/Y Plot segfaults Bruce Hill
RE: EDM X/Y Plot segfaults Baily, Scott A
Re: EDM X/Y Plot segfaults Christoph Schroeder
RE: EDM X/Y Plot segfaults Sinclair, John William
Prev: RE: EDM X/Y Plot segfaults Sinclair, John William
Next: EPICs suddenly not connecting to devices John Teah
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EDM X/Y Plot segfaults Baily, Scott A
ANJ, 31 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
