1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Virtual circuit unresponsive on CA Gateway
To: 윤상원 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Aug 2018 15:28:53 +0000
Hi Sangwon,
Take a look at this: https://bugs.launchpad.net/epics-base/+bug/541238
At the end, Andrew said “Probably fixed in later versions of Base ….”, “R3.14.10 released”.
Which version of Base is your CA gateway built against?
Best,
Yong
From: <[email protected]> on behalf of 윤상원 <[email protected]>
Date: Tuesday, August 28, 2018 at 3:29 AM
Subject: Virtual circuit unresponsive on CA Gateway
Hello,
We are running several CA gateways for providing access to PVs for clients including OPIs.
I observed the warning message “Virtual circuit unresponsive” on log files of the CA gateways.
For instance,
Aug 28 15:29:19 Warning: Virtual circuit unresponsive 172.17.101.21:5064
Aug 28 15:53:40 Warning: Virtual circuit unresponsive 172.17.101.80:5064
In addition, when the message is logged on a log file, connections to PVs of the IOC server related with the message (ex. 172.17.101.21) are disconnected.
At the time, connection to the same PVs which directly connects to the IOC server instead of CA gateway is still continued and client (camonitor) can receive changes from the IOC without disturbance.
For the information, we are running two versions of CA gateways, v2.0.4.0 and v2.1.0.
Could anyone please share any guidance or comments in the case?
Thanks in advance for your guidance or any comments.
Sangwon
RE: Virtual circuit unresponsive on CA Gateway 윤상원
Prev: Virtual circuit unresponsive on CA Gateway 윤상원
Next: Macro definitions for compiling areaDetector R3.3.2 Li, Ji
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Virtual circuit unresponsive on CA Gateway 윤상원
ANJ, 29 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
