1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Macro definitions for compiling areaDetector R3.3.2
Date: Tue, 28 Aug 2018 17:18:32 +0000
Hi All,
I'm compiling areaDetector R3.3.2 on a Windows 10 machine. Macros (EPICS_BASE, ADCORE, ...) are defined at areaDetector level (e.g., EPICS_BASE in areaDetector-R3-3-2\configure\RELEASE_SUPPORT.local, ADCORE in areaDetector-R3-3-2\configure\RELEASE_LIBS.local) as instructed.
When compiling modules, it looks these definitions are removed as the compiler complains unable to find some files. For example, when compiling NDDriverStdArrays:
make -C ./src install
make[5]: Entering directory 'C:/EPICS/synApps-6-0/support/areaDetector-R3-3-2/NDDriverStdArrays/iocs/NDDriverStdArraysIOC/NDDriverStdArraysApp/src'
Makefile:27: /ADApp/commonDriverMakefile: No such file or directory
make[5]: *** No rule to make target '/ADApp/commonDriverMakefile'.  Stop.
In areaDetector-R3-3-2\NDDriverStdArrays\iocs\NDDriverStdArraysIOC\NDDriverStdArraysApp\src\Makefile, the file was included as:
include $(ADCORE)/ADApp/commonDriverMakefile
I change $(ADCORE) to the full path to ADCore, and the error disappeared. But new errors appeared:
make[6]: Entering directory 'C:/EPICS/synApps-6-0/support/areaDetector-R3-3-2/NDDriverStdArrays/iocs/NDDriverStdArraysIOC/NDDriverStdArraysApp/src/O.windows-x64-static'
Creating dbd file NDDriverStdArraysApp.dbd
perl -CSD C:/EPICS/base-7.0.1.1/bin/windows-x64-static/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -IC:/EPICS/base-7.0.1.1/dbd -o NDDriverStdArraysApp.dbd NDDriverStdArraysSupport.dbd
perl -CSD C:/EPICS/base-7.0.1.1/bin/windows-x64-static/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -IC:/EPICS/base-7.0.1.1/dbd    -o NDDriverStdArraysApp_registerRecordDeviceDriver.cpp ../O.Common/NDDriverStdArraysApp.dbd NDDriverStdArraysApp_registerRecordDeviceDriver C:/EPICS/synApps-6-0/support/areaDetector-R3-3-2/NDDriverStdArrays/iocs/NDDriverStdArraysIOC
perl -CSD C:/EPICS/base-7.0.1.1/bin/windows-x64-static/mkmf.pl  -m NDDriverStdArraysApp_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include   -I../../../../../include -IC:/EPICS/base-7.0.1.1/include/compiler/msvc -IC:/EPICS/base-7.0.1.1/include/os/WIN32 -IC:/EPICS/base-7.0.1.1/include           NDDriverStdArraysApp_registerRecordDeviceDriver.obj NDDriverStdArraysApp_registerRecordDeviceDriver.cpp
Installing created dbd file ../../../dbd/NDDriverStdArraysApp.dbd
cl -EHsc -GR               -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include   -I../../../../../include -IC:/EPICS/base-7.0.1.1/include/compiler/msvc -IC:/EPICS/base-7.0.1.1/include/os/WIN32 -IC:/EPICS/base-7.0.1.1/include           -c NDDriverStdArraysApp_registerRecordDeviceDriver.cpp
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:NDDriverStdArraysApp.exe        NDDriverStdArraysApp_registerRecordDeviceDriver.obj NDDriverStdArraysAppMain.obj     ../../../../../lib/windows-x64-static/NDDriverStdArrays.lib  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
NDDriverStdArraysApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol iocshRegister referenced in function "int __cdecl Registration(void)" (?Registration@@YAHXZ)
NDDriverStdArrays.lib(NDDriverStdArrays.obj) : error LNK2001: unresolved external symbol iocshRegister
NDDriverStdArraysApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol iocshRegisterCommon referenced in function "int __cdecl Registration(void)" (?Registration@@YAHXZ)
NDDriverStdArraysApp_registerRecordDeviceDriver.obj : error LNK2019: unresolved external symbol iocshPpdbbase referenced in function rrddCallFunc
I removed NDDriverStdArrays from the compiling list in the areaDetector-R3-3-2\configure\RELEASE.local and then same errors occurred when compiling another module (pvaDriver).
I don't think it the right way to find all the definitions that cause such errors and change them manually. Did I missed some configurations?
Thanks.
-Ji Li
RE: Macro definitions for compiling areaDetector R3.3.2 Mark Rivers
Prev: Re: Virtual circuit unresponsive on CA Gateway Hu, Yong
Next: RE: Macro definitions for compiling areaDetector R3.3.2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Virtual circuit unresponsive on CA Gateway 윤상원
ANJ, 07 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
