1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: Re: the same question to "a simple question about pyepics"
To: EPICS Tech Talk <[email protected]>
Date: Thu, 30 Aug 2018 08:44:42 +0200
The EPICS web site has a list of available device supports.
In addition, searching for "epics driver <your device>" is always a good idea.
For Siemens S7 PLCs, there are basically two protocol options:
Native S7 protocol using libnodave: http://oss.aquenos.com/epics/s7nodave/
Both drivers are stable, well tested, widely used and work fine. The basic difference:
Block read/write offers high performance, but requires programming on the PLC.
The S7 protocol is less performant, but handled by the PLC "firmware" and needs no user programming on that side.
Hope this helps,
~Ralph
On Thu, 30 Aug 2018 at 08:33, 成威黄瀛 <[email protected]> wrote:
Hi, Peter,
One more question, as I need to connect to PLC too. Could you also give me a guideline, or where I can find related documents on how to connect to PLC? Take Simens 1200 for example.
Thanks.
黄 瀛
*****开票信息*****
名称:绵阳成威实验室工程技术有限公司
税号:915107 0455 1000 912T
注册地址:四川省绵阳市游仙区仙人路一段32号
开户银行:中国银行绵阳游仙支行
账号:1279 5046 6834
*****送货信息*****
地址:四川省绵阳市游仙区游仙镇仙童街一号,电商谷
联系人:黄瀛
电话:18784065819
Ying Huang
Chengwei Lab&Engineering Company
No1 Xiantong Street, Youxian Area, Mianyang City, Sichuan Province, China
86 0816 2967213
------------------ 原始邮件 ------------------
发件人: "Peter.Milne"<[email protected]>;
发送时间: 2018年8月30日(星期四) 凌晨0:26
收件人: "成威黄瀛"<[email protected]>;"tech-talk"<[email protected]>;
主题: Re: the same question to "a simple question about pyepics"
Hello Ying Huang
On 29/08/18 17:10, 成威黄瀛 wrote:
> Plus, this is just a beginning of mine and I do not connect any  device on my laptop. I just try it on a Virtual Mechine and follow the  easiest example hoping to get the entrance.
> Hope to get feedback. Thanks in advance.
> Hi,
> I am just facing the same question with that email "a simple question about pyepics".
> OS is redhat6, python is 2.7.6
> Here is what I tried:
> 1,    [root@localhost linux64]# echo $PYEPICS_LIBCA
> /test/base/lib/linux-x86_64/libca.so
> 2,    [root@localhost linux64]# echo $EPICS_BASE
> /test/base
> 3,    [root@localhost linux64]# echo $EPICS_HOST_ARCH
> linux-x86_64
> 4,    in python I am typing
> Python 2.7.6 (default, Aug 28 2018, 07:42:21)
> [GCC 4.4.7 20120313 (Red Hat 4.4.7-16)] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
>>>> from epics import caget
>>>> m1 = caget('root:ai2')
> cannot connect to root:ai2
> 5,   PV named 'root:ai2' does exist
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq sncExample, "user=root"
> epics> dbl
> root:xxxExample
> root:calcExample
> root:calcExample1
> root:calc1
> root:calcExample2
> root:calc2
> root:calcExample3
> root:calc3
> root:subExample
> root:aSubExample
> root:compressExample
> root:aiExample
> root:aiExample1
> root:ai1
> root:aiExample2
> root:ai2
> root:aiExample3
> root:ai3
> What can I do then?
I would try the standard epics Channel Access CA tools eg
https://epics.anl.gov/base/R3-14/12-docs/CAref.html#caget
from the command line
caget root:ai2
or
camonitor root:ai2
If that doesn't work, your problem is not pyepics, but CA in general.
Could be firewall or name resolution issue.
https://epics.anl.gov/base/R3-14/12-docs/CAref.html#firewall
https://epics.anl.gov/base/R3-14/12-docs/CAref.html#EPICS
EPICS_CA_ADDR_LIST=ip-addr
Cheers
Peter
> 黄 瀛
> *****开票信息*****
> 名称:绵阳成威实验室工程技术有限公司
> 开户银行:中国银行绵阳游仙支行
> 账号:1279 5046 6834
> *****送货信息*****
> 联系人:黄瀛
> 电话:18784065819
> Ying Huang
> 86 0816 2967213
Peter Milne
Director of Sales
www.d-tacq.com
the same question to "a simple question about pyepics" =?gb18030?b?s8nN/rvG5a0=?=
Re: the same question to "a simple question about pyepics" Peter Milne
=?gb18030?b?u9i4tKO6IHRoZSBzYW1lIHF1ZXN0aW9uIHRvICJh?==?gb18030?b?IHNpbXBsZSBxdWVzdGlvbiBhYm91dCBweWVwaWNz?==?gb18030?b?Ig==?= =?gb18030?b?s8nN/rvG5a0=?=
Prev: Re: the same question to "a simple question about pyepics" Peter Milne
Next: Re: areaDetector driver for webcams? Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Next: areaDetector driver for webcams? Bruno Martins
ANJ, 30 Aug 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
