Hi, I am following this guideline to make connection between epics and PLC. http://metis.ipfn.ist.utl.pt/index.php?title=FUSION_Collaborations/ESTHER/Slow_Control/EPICS_%26_Siemens_PLC_Tutorial http://oss.aquenos.com/epics/s7nodave/docs/2.1.3/manual.html#recordreference.deviceaddress In the second link, I think I reach Step4, which means I can type s7nodaveConfigurePollGroup and s7nodaveConfigureIsoTcpPort command However, in the first link, I do not understand the part below. Where can I modify the record(bi, "S7:biI1_5poll") ??????? Than I can visit the record by sequencer program??????? Sorry I got big confused here.
--------------- Poll GroupsAll the input records in the database have a SCAN field. The IOC
application will scan the value of each record at the interval defined
in the SCAN field. For a SCAN field of "0.1 second" of a input record,
the IOC application will query the PLC for that record's value once
every 100 miliseconds.
However, EPICS treats each query independently, so by setting the
SCAN field of every input record in this way, EPICS will query each
value thorugh the local network and wait for the response before moving
on to the next query, resulting in delayed responses.
The s7nodave library allows records to be assinged to polling
groups. All the records in a pollgroup are queried in the same network
packet, greatly reducing response lag.
In order to assign an input record to a poll group using the
s7nodave library, one must set the SCAN field to "I/O Intr", and the INP
field to "@myPLC(PG=[POLLGROUP_NAME]) [PLC_ADDR]". This can be seen in the example below for the PV S7:biI1_5poll.
field(SCAN, "I/O Intr")
field(DTYP, "s7nodave")
field(INP, "@myPLC(PG=1s) I1.5")
field(DESC, "S7 PLC I1.5 Binary Input POLLING")
Ommiting (PG=[POLLGROUP_NAME]) will assign the PV record to the "default" poll group. ---------------------------------------------- Sequencer ProgramThe example sequencer program inside this testS7 is a simple state-machine that monitors the value of a PLC port and sets another port to high or low accordingly. This program sequencer can be seen in the [testS7]/tests7App/src/snctests7.stt file: program snctests7 double v;
short light;
assign v to "S7:biQ1_0";
monitor v;
assign light to "S7:boQ0_7";
ss ss1 {
state init {
when (delay(1)) {
printf("snctests7: Startup delay over\n");
printf("snctests7: Going to low\n");
} state low
state low {
when (v >= 0.5) {
printf("snctests7: Changing to high %f\n",v);
light = TRUE;
pvPut(light);
} state high
state high {
when (v <= 0.5) {
printf("snctests7: Changing to low %f\n",v);
light = FALSE;
pvPut(light);
} state low
} ------------------ 黄 瀛 *****开票信息***** 名称:绵阳成威实验室工程技术有限公司 税号:915107 0455 1000 912T 注册地址:四川省绵阳市游仙区仙人路一段32号 开户银行:中国银行绵阳游仙支行 账号:1279 5046 6834 *****送货信息***** 地址:四川省绵阳市游仙区游仙镇仙童街一号,电商谷 联系人:黄瀛 电话:18784065819 ************************************************ Ying Huang Chengwei Lab&Engineering Company No1 Xiantong Street, Youxian Area, Mianyang City, Sichuan Province, China 86 0816 2967213
ANJ, 06 Sep 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
