1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Keithley 2001 Digital multimeter IOC
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 8 Sep 2018 21:07:15 +0000
Hi Rory,
The synApps “ip” module has support for the Keithley 2001.
https://github.com/epics-modules/ip/tree/master/ipApp/src
The important files are:
State notation language program:
https://github.com/epics-modules/ip/blob/master/ipApp/src/Keithley2kDMM.st
Database:
https://github.com/epics-modules/ip/blob/master/ipApp/Db/Keithley2kDMM_mf.db
medm screen:
https://github.com/epics-modules/ip/blob/master/ipApp/op/adl/Keithley2kDMM_mf.adl
This implementation allows each channel on the plugin card to have a different function (volts, ohms, temperature, etc.).
The I/O uses asyn, and so it is independent of whether you use serial or GPIB.  I have tested both.  The newer versions of this meter (2700 series) have Ethernet, and that also works.
Is there a reason you are using GPIB rather than RS-232?  I believe I found that GPIB was no faster, and it is considerably less convenient in most cases.
Let me know if you have questions.
From: [email protected] <[email protected]> On Behalf Of [email protected]
Sent: Friday, September 7, 2018 11:17 AM
To: [email protected]
Subject: Keithley 2001 Digital multimeter IOC
Hello,
I am working as part of the IBEx project at ISIS in the UK.
I am looking to support the Keithley 2001 Digital Multimeter using a GPIB bus.
Has anyone created an IOC for this device?
Kind regards,
Rory Potter
Keithley 2001 Digital multimeter IOC [email protected]
Prev: RE: Problems with soft motors Mark Rivers
Next: Re: Problems with soft motors Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Keithley 2001 Digital multimeter IOC [email protected]
Next: Problem with 7.0.1.1 static built pvget Phillip Sorensen
ANJ, 10 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
