1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: question on architecture of epics and opc
From: "=?gb18030?b?s8nN/rvG5a0=?=" <[email protected]>
To: "=?gb18030?b?dGVjaC10YWxr?=" <[email protected]>
Date: Fri, 14 Sep 2018 09:51:21 +0800
Hi, TechTalk,
Here I have a system architecture block showed as below.
Background: Last week I set up an environment consists of epics, python, s7nodave, which I can talk to PLC(siemens 1200). I use wxpython to generate a GUI to turn on a light of PLC, also I use django framework to generate a web page, in which I can control a light of PLC by clicking a button. The environment is in Ubantu.
1, My first question is, according to this function block, there are two parallel methods to communicate with hardware. But, why need OPC approach, since I can talk to PLC without OPC? What is the difference between the method I use and OPC?
2, My second question is: the hardware in the bottom layer, is a serial of PLCs. Manufacturer of these PLCs offers a DLL file, which is a API of these PLCs. Does that mean I can only build the whole system in windows OS but not Linux? Since DLL is a concept of windows. Also, OPC is also a concept of windows but not Linux.
3, Last, can you comment on the system block below? Anything helps me to get more clear about it is welcome.
Thanks a lot ^_^ ^_^ ^_^
Ying Huang
Chengwei Lab&Engineering Company
No1 Xiantong Street, Youxian Area, Mianyang City, Sichuan Province, China
86 0816 2967213
Prev: quadEM R9-2 now available Mark Rivers
Next: PCAS 4.13.2 available Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 14 Sep 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
