1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Bypassing Options in ImageMode in AreaDetector
To: <[email protected]>
Date: Fri, 14 Sep 2018 10:54:05 -0500
On 09/14/2018 09:08 AM, Iain Marcuson wrote:
> That is what I did in my first implementation, although due to how I set
> things up I was modifying the ADCore template, which doesn’t seem very
> portable.  I may have to make a separate AreaDetector project for our
> sensor and modify that.
You should be able to load another .db file that just overwrites the
field values that were set for this record instance by the original
ADCore database file. As long as the record type is the same as the
original and the startup script hasn't set the dbRecordsOnceOnly
variable there is nothing preventing you from setting record fields for
a record in more than one .db file, the last value set always wins.
- Andrew
> *From:* Mark Rivers <[email protected]>
> *Sent:* Friday, September 14, 2018 10:05 AM
> *To:* Iain Marcuson <[email protected]>;
> [email protected]
> *Subject:* RE: Bypassing Options in ImageMode in AreaDetector
> Hi Iian,
> You can do it in a simpler way.  You can just redefine the fields of the
> existing ImageMode record in the database for your detector.  You don’t
> need to leave a gap.  The ONVL field can be 2, it does not have to be 1.
> Here is an example from ADAndor/andorApp/Db/andorCCD.template where
> additional choices were added:
> record(mbbo, "$(P)$(R)ImageMode")
>    field(ZRST, "Single")
>    field(ZRVL, "0")
>    field(ONST, "Multiple")
>    field(ONVL, "1")
>    field(TWST, "Continuous")
>    field(TWVL, "2")
>    field(THST, "Fast Kinetics")
>    field(THVL, "3")
>    field(VAL,  "2")
> record(mbbi, "$(P)$(R)ImageMode_RBV")
>    field(ZRVL, "0")
>    field(ONVL, "1")
>    field(TWVL, "2")
>    field(THVL, "3")
>    field(SCAN, "I/O Intr")
> In your case you can do:
>    field(ZRVL, "0")
>    field(ONST, "Continuous")
>    field(ONVL, "2")
>    field(ZRVL, "0")
>    field(ONVL, "2")
> Mark
> *From:* [email protected]
> <mailto:[email protected]> <[email protected]
> <mailto:[email protected]>> *On Behalf Of *Iain Marcuson
> *Sent:* Friday, September 14, 2018 8:51 AM
> *To:* [email protected] <mailto:[email protected]>
> *Subject:* Bypassing Options in ImageMode in AreaDetector
> I am using areaDetector in a product.  We only want to use “Single” and
> “Continuous” ImageMode, not “Multiple”.  In the first implementation, I
> modified ADBase.template to remove the “Multiple” option.  For a more
> portable solution, I made a new mbbo record without the Multiple option,
> and set the OUT field to $(P)$(R)ImageMode.  However, I had to define
> “ZRVAL” and “TWVAL”, skipping “ONVAL” (Multiple), leaving a gap in a
> drop-down menu.  Is there a way to avoid this gap?
> Thank you,
> *Iain Marcuson*
> Software Engineer, Sydor Technologies
> 585.278.1168 | www.SydorTechnologies.com <http://www.sydortechnologies.com/>
> Skype: [email protected]
Bypassing Options in ImageMode in AreaDetector Iain Marcuson
RE: Bypassing Options in ImageMode in AreaDetector Mark Rivers
RE: Bypassing Options in ImageMode in AreaDetector Iain Marcuson
Prev: RE: Bypassing Options in ImageMode in AreaDetector Iain Marcuson
Next: RE: Bypassing Options in ImageMode in AreaDetector Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 14 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
