1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: time series circular buffer
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 21 Sep 2018 12:38:47 +0000
Thanks again Mark. I'll give it a run.
BTW, I noticed that in OPIs from ADCore 3-3-2, NDPluginBase.opi entry field next to 'Array address' wants to be of type String while it should be Decimal.
Best,
Hinko
Hinko Kocevar
Beam Diagnostics Engineer
European Spallation Source ERIC
P.O Box 176, SE-221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, 224 84 Lund
Mobile: +46-721-79 22 58
Phone:  +46-46-888 32 58
Web:    www.esss.se
On 2018-09-20 18:32:51+02:00 Mark Rivers wrote:
I have made 2 more changes:
Added the NDPluginTimeSeries TSTimePerPointLink.DOL to autosave.
Changed all of the statistics time series plots  (NDStatsTimeSeriesPlot.adl, NDStatsTimeSeriesBasicAll.adl, NDStatsTimeSeriesCentroidAll.adl) so that they use the TSTimeAxis waveform for the horizontal axis.  The horizontal axis is thus now in units of seconds rather than point number.
I did the autoconversion of these screens to edm, caQtDM, and CSS-BOY.  Everything is on the master branch on Github.
Sent: Thursday, September 20, 2018 10:19 AM
To: Mark Rivers <[email protected]>; [email protected]; [email protected]
Hi Mark,
thanks for fixing the issues!
Best,
Hinko
Hinko Kocevar
Web:    www.esss.se
On 2018-09-20 16:15:33+02:00 Mark Rivers wrote:
Hi Hinko,
&gt; I get only two distinct timestamps displayed in NDPluginTimeseries plugin window. The Unique ID also toggles between two values. I have a test case with the following startup script:
I have fixed this.  The problem was that the NDPluginStats was not setting the uniqueId, timeStamp, and epicsTS of the time series NDArrays that it was passing to the NDPluginTimeSeries plugin.
The fix is in the master branch on Github.
I also found that the time series TimePerPointLink record is not autosave.  I will fix that today.
Sent: Thursday, September 20, 2018 7:45 AM
To: 'Hinko Kocevar'; [email protected]; [email protected]
Hi Hinko,
Ø  I get only two distinct timestamps displayed in NDPluginTimeseries plugin window. The Unique ID also toggles between two values. I have a test case with the following startup script:
I see something similar, although I see a larger number of values they are toggling between.  These are clearly the stale values of the UniqueID and timestamps from the NDArray it got from the NDArrayPool.  I will fix this.  The questions is what values should it use?  The values from last input array before the average was computed?
Ø  When changing the Time link field value (sets DOL), the Time/point RBV does not update. I have to use caput $(P)$(R):TSTimePerPointLink.PROC 1 to have it process.
If you want this value to update when the external value changes you need to use the CP attribute on the PV you enter into the link.  I just tested this using the following link and it worked fine: “13SIM1:cam1:AcquirePeriod_RBV CP”
TSNumAverage in the time-series plugin updated as it should when the simDetector AcquirePeriod was changed.
Sent: Thursday, September 20, 2018 4:06 AM
Hi Mark,
I'm trying to use the new stats and time series plugins. It got it to work, with two comments.
a)
NDStatsConfigure("ST.LCR.CH$(C)", $(QSIZE), 0, "$(PORT)", $(C), 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDStats.template",       "P=$(PREFIX),R=STLCRCH$(N):,  PORT=ST.LCR.CH$(C),ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=$(XSIZE),YSIZE=$(YSIZE),NCHANS=$(NCHANS),NDARRAY_PORT=$(PORT),NDARRAY_ADDR=$(C),TS_PORT=STTS.LCR.CH$(C)")
NDTimeSeriesConfigure("STTS.LCR.CH$(C)", $(QSIZE), 0, "ST.LCR.CH$(C)", 1, 23)
dbLoadRecords("NDTimeSeries.template",  "P=$(PREFIX),R=STLCRCH$(N):TS:, PORT=STTS.LCR.CH$(C),ADDR=0,TIMEOUT=1,NDARRAY_PORT=ST.LCR.CH$(C),NDARRAY_ADDR=1,NCHANS=$(NCHANS),TIME_LINK=$(PREFIX)TickValueR,ENABLED=1")
dbLoadRecords("NDTimeSeriesN.template", "P=$(PREFIX),R=STLCRCH$(N):TS:Min:, PORT=STTS.LCR.CH$(C),ADDR=0,TIMEOUT=1,NCHANS=$(NCHANS),ENABLED=1,NAME=Min")
dbLoadRecords("NDTimeSeriesN.template", "P=$(PREFIX),R=STLCRCH$(N):TS:Max:, PORT=STTS.LCR.CH$(C),ADDR=3,TIMEOUT=1,NCHANS=$(NCHANS),ENABLED=1,NAME=Max")
dbLoadRecords("NDTimeSeriesN.template", "P=$(PREFIX),R=STLCRCH$(N):TS:Ave:, PORT=STTS.LCR.CH$(C),ADDR=6,TIMEOUT=1,NCHANS=$(NCHANS),ENABLED=1,NAME=Average")
The stats plugin shows the proper Uniques ID and timestamp, same as the driver.
b)
Hinko
Hinko Kocevar
E-mail: [email protected]<mailto:[email protected]>
Web:    www.esss.se<http: www.esss.se="">
On 2018-06-26 10:16:24+02:00 [email protected]<mailto:[email protected]> wrote:
Hi Mark,
thank you for the fast solution! I'll give it run in the next weeks and report!
Best,
Hinko
Sent: Monday, June 25, 2018 10:30:10 PM
To: Hinko Kocevar; [email protected]<mailto:[email protected]>; [email protected]<mailto:[email protected]>
Hi Hinko,
I have implemented the change to the NDPluginStats plugin using the second method I suggested:
- Move the time series code out of the statistics plugin and have the statistics plugin send the time points as NDArrays to time series plugins.
This has the benefit of reducing the code by 240 lines while adding the functionality of the Circular Buffer mode.
The only downside is that it breaks backwards compatibility.  The names of the PVs for the time-series arrays are unchanged, but the PVs to control the time-series (start/stop, number of time points, etc.) are slightly changed.  I think this is probably OK because I doubt if these are widely used in client scripts.
I have put the new version in this branch of ADCore on Github: https://github.com/areaDetector/ADCore/tree/stats_time_series.  There is a pending pull-request for it.  If you (or anyone else) wants to test and comment that would be welcome.
Sent: Tuesday, June 19, 2018 8:28 AM
To: [email protected]<mailto:[email protected]>; [email protected]<mailto:[email protected]>; Mark Rivers &lt;[email protected]&gt;
Hi Mark,
sounds like both approaches might be acceptable. I guess it is about code duplication vs. number of different plugins one needs to get this feature, when it comes to deciding where to place this.
thanks,
hinko
Hinko Kocevar
E-mail: [email protected]&lt;mailto:[email protected]&gt;<mailto:[email protected]&lt;mailto:[email protected]&gt>;
Web:    www.esss.se&lt;http<http: www.esss.se&lt;http="">: www.esss.se=""&gt;<http: www.esss.se="%22%22>">;
On 2018-06-16 01:07:11+02:00 Mark Rivers wrote:
Hi Hinko,
I think it would be useful to be able to run the time series in circular buffer mode.  There are 2 ways this might be done:
- Add the code for circular buffer mode to the statistics plugin
I'm not sure which is best.
I have created an issue for this in ADCore.
-----Original Message-----
From: [email protected]&lt;mailto:[email protected]&gt;<mailto:[email protected]&lt;mailto:[email protected]&gt>; &lt;[email protected]&lt;mailto:[email protected]&gt;&amp;gt; On Behalf Of Hinko Kocevar
Sent: Friday, June 15, 2018 3:55 AM
To: [email protected]&lt;mailto:[email protected]&gt;<mailto:[email protected]&lt;mailto:[email protected]&gt>;; Tech-talk &lt;[email protected]&lt;mailto:[email protected]&gt;&amp;gt;
Subject: Re: time series circular buffer
Hi Tom,
thanks for the suggestion, I have not used this particular plugin so far. I'll give it a try!
Cheers,
Hinko
Sent: Friday, June 15, 2018 9:44:57 AM
To: Hinko Kocevar; Tech-talk
There is the NDPluginAttrPlot plugin which takes any numeric stamped NDAttributes (like the ones the NDPluginStats produces) and puts them in a circular buffer, periodically pushing the last N samples to a set of waveforms. We use it to plot arbitrary attributes against each other.
http://cars9.uchicago.edu/software/epics/NDPluginAttrPlot.html
Tom
&amp;gt; -----Original Message-----
&amp;gt; From: [email protected]&lt;mailto:[email protected]&gt;<mailto:[email protected]&lt;mailto:[email protected]&gt>; &lt;[email protected]&lt;mailto:[email protected]&gt;&amp;gt; On
&amp;gt; Behalf Of Hinko Kocevar
&amp;gt; Sent: 15 June 2018 07:38
&amp;gt; To: Tech-talk &lt;[email protected]&lt;mailto:[email protected]&gt;&amp;gt;
&amp;gt; Subject: time series circular buffer
&amp;gt;
&amp;gt; Hi,
&amp;gt;
&amp;gt; in areaDetector NDPluginStats plugin I can get nice timeseries plots
&amp;gt; for max, mean, min.
&amp;gt; After the number of predefined points are collected the storing stops.
&amp;gt; Is there a way to configure timeseries buffer as a circular buffer?
&amp;gt; I've noticed that NDTimeSeries has this feature, but I'm failing to
&amp;gt; find one in NDPluginStats.
&amp;gt;
&amp;gt; Thanks,
&amp;gt;
&amp;gt; Hinko Kocevar
&amp;gt;
&amp;gt; Beam Diagnostics Engineer
&amp;gt; European Spallation Source ERIC
&amp;gt; P.O Box 176, SE-221 00 Lund, Sweden
&amp;gt; Visiting address: Odarslövsvägen 113, SE-224 84 Lund , Sweden
&amp;gt;
&amp;gt; Mobile: +46-721-79 22 58
&amp;gt; Phone:  +46-46-888 32 58
&amp;gt;
&amp;gt; E-mail: [email protected]&lt;mailto:[email protected]&gt;<mailto:[email protected]&lt;mailto:[email protected]&gt>;
&amp;gt; Web:    www.esss.se&lt;http<http: www.esss.se&lt;http="">: www.esss.se=""&gt;<http: www.esss.se="%22%22>">;
&amp;gt;&amp;gt;&amp;gt;&amp;gt;&amp;gt;
&lt;/http:&gt;&lt;/mailto:[email protected]&gt;&lt;/[email protected]&lt;mailto:[email protected]&gt;&lt;/[email protected]&lt;mailto:[email protected]&gt;&lt;/mailto:[email protected]&gt;&lt;/[email protected]&lt;mailto:[email protected]&gt;&lt;/mailto:[email protected]&gt;&lt;/[email protected]&lt;mailto:[email protected]&gt;&lt;/mailto:[email protected]&gt;&lt;/[email protected]&lt;mailto:[email protected]&gt;&lt;/mailto:[email protected]&gt;&lt;/http:&gt;&lt;/mailto:[email protected]&gt;&lt;/[email protected]&gt;&lt;/[email protected]&gt;&lt;/[email protected]&gt;
</http:></http:></mailto:[email protected]&lt;mailto:[email protected]&gt></mailto:[email protected]&lt;mailto:[email protected]&gt></mailto:[email protected]&lt;mailto:[email protected]&gt></mailto:[email protected]&lt;mailto:[email protected]&gt></mailto:[email protected]&lt;mailto:[email protected]&gt></http:></http:></mailto:[email protected]&lt;mailto:[email protected]&gt></mailto:[email protected]></mailto:[email protected]></mailto:[email protected]></mailto:[email protected]></mailto:[email protected]></http:></mailto:[email protected]></[email protected]></[email protected]>
RE: time series circular buffer Mark Rivers
time series circular buffer Hinko Kocevar
RE: time series circular buffer [email protected]
Re: time series circular buffer Hinko Kocevar
RE: time series circular buffer Hinko Kocevar
Re: time series circular buffer Mark Rivers
Prev: Re: BlackFly S with ADSpinnaker [SEC=UNCLASSIFIED] Mark Rivers
Next: RE: time series circular buffer Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Prev: RE: time series circular buffer Mark Rivers
ANJ, 21 Sep 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
