1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ADPicam problem
To: [email protected]
Cc: "Engbretson, Mark S." <[email protected]>
Date: Tue, 02 Oct 2018 11:27:48 +0200
Hi Mark,
It looks a bit that I was not clear enough in my problem description:
Assume that I have one USB camera connected to my PC and on the Network there
is some other camera from PrincetonIntruments. The driver will connect to the
first camera it finds.
But which one is it? Its a random choice! Sometimes USB sometimes ethernet
will win. So one does not know which camera will pop up.
That's why the discovery method was implemented, I guess. It will build a list
of all available cameras, from which you can the select the one you want to
operate with this driver instance.
In my dmesg output I find the following message:
usb 2-1.1: usbfs: process xxxxx (st.cmd) did not claim interface 0 before use
So that seems to be a bug in the PICam library.
I guess I have to contact Princeton Instruments with that.
Regards
Jörn
Am Dienstag, 2. Oktober 2018, 09:34:10 CEST schrieb Engbretson, Mark S.:
> I believe that this is the expected behavior of that area detector. You can
> have multiple real or simulated cameras configured, but you can only use
> one at a time. One of the display elements is a menu option of the possible
> cameras which allows you to pick and choice which one you want active at
> any given time.
> I do not think that any single AD allows for multiple active cameras. The
> controls are not made for that.
> If your case, you really need to configure yours as 2 different ones, and
> have each manually select for the particular one the you want - which only
> works if you do not have 2 of the same camera type.
> On Oct 2, 2018, at 02:00, Jörn Dreyer <[email protected]> wrote:
> Hello,
> I'm currently setting up a system that uses a PrincetonImaging PIXIS camera.
 As these cameras use an USB interface I have to use the latest version of
> the PICAM library (5.1.2) from Princeton.
> With this library the driver connects at startup but looses the camera
> during
 the initialization phase. In the hardware setup routine the driver
> registers a callback function for the PICAM_Discovery mechanism. This
> function seems to loos the communication over USB with the connected camera
> if another thread talks to the camera.
> Has anybody else observed this behavior? I could get around this problem if
> I
 comment out the calls to the PICAM_AdvancedRegisterForDiscovery
> function. But then the driver is only able to use the first detected
> camera. If I would connect two, I can not select the one I want to use.
> Regards
> Jörn
Attachment: smime.p7s
Description: S/MIME cryptographic signature
ADPicam problem Jörn Dreyer
Re: ADPicam problem Engbretson, Mark S.
Prev: Re: ADPicam problem Engbretson, Mark S.
Next: RE: Stream device does not recognize a custom record type Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: p2p gateway server Shen, Guobao
ANJ, 02 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
