Hi Jason,
I had a similar problem with our Eiger 500, but in my case it could only not find link_3 and link_4. This is an expected error on the Eiger 500K because only link_1 and link_2
exist. I fixed the driver for the 500K in this commit:
https://github.com/areaDetector/ADEiger/commit/50e13b24226e6eb702bd88a8dab16ed280c99137#diff-d1d617fd8427431b5658f2ef750e0a74
In your case it is not finding any of the links (link_1 through link_4), probably in the eigerDetector::eigerStatus() function. That does not make sense to me.
Is the detector working otherwise? Can you collect an image?
Hello,
I'm attempting to setup a Dectris Eiger R 1M with EPICS (3.15.5) and have compiled the latest version of asyn, ADSupport, ADCore, and ADEiger driver. Upon running st.cmd, I receive the following
errors:
eigerDetectorConfig("EIG", "10.42.41.10", 0, 0)
RestApi::get: [param=description] server returned error code 404
2018/10/02 15:43:48.583 Param[DESCRIPTION]::baseFetch: [param=description] unable to parse json response
2018/10/02 15:43:48.583 Param[DESCRIPTION]::fetch<string>: [param=DESCRIPTION] underlying baseFetch failed
2018/10/02 15:43:48.583 eigerDetector::eigerDetector: Eiger seems to be uninitialized
Initializing... (may take a while)
RestApi::get: [param=link_1] server returned error code 500
2018/10/02 15:44:07.686 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:07.686 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
RestApi::get: [param=link_2] server returned error code 500
2018/10/02 15:44:07.689 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:07.689 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
RestApi::get: [param=link_3] server returned error code 500
2018/10/02 15:44:07.693 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:07.693 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
2018/10/02 15:44:07.816 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:07.816 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
2018/10/02 15:44:07.825 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:07.825 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
2018/10/02 15:44:07.834 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:07.834 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
epics> eigerDetectorConfig("EIG", "$(EIGERIP)", 0, 0)
2018/10/02 15:44:42.327 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:42.327 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
2018/10/02 15:44:42.336 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:42.336 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
2018/10/02 15:44:42.345 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:42.345 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
2018/10/02 15:44:42.500 Param[LINK_1]::baseFetch: [param=link_1] unable to parse json response
2018/10/02 15:44:42.500 Param[LINK_1]::fetch<int>: [param=LINK_1] underlying baseFetch failed
2018/10/02 15:44:42.509 Param[LINK_2]::baseFetch: [param=link_2] unable to parse json response
2018/10/02 15:44:42.509 Param[LINK_2]::fetch<int>: [param=LINK_2] underlying baseFetch failed
2018/10/02 15:44:42.518 Param[LINK_3]::baseFetch: [param=link_3] unable to parse json response
2018/10/02 15:44:42.518 Param[LINK_3]::fetch<int>: [param=LINK_3] underlying baseFetch failed
If you need any other information, please let me know.
Any help figuring this out would be greatly appreciated.
Thank you.
User Support Specialist Sr.
Molecular Biosciences/MIM/CSGID
Computational Facility Manager - Structural Biology Facility
