1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CameraLink and ADPCO
To: "'Engbretson, Mark S.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 6 Oct 2018 13:27:57 +0000
Follow-up:
The problem is with the pcaEdgePlugin that is part of the ADPCO repository.  If that plugin is commented out in the startup script the PCO driver and other plugins work fine.  We need to find the problem in that plugin.
Sent: Friday, October 5, 2018 4:47 PM
To: 'Engbretson, Mark S.'; [email protected]
Subject: RE: CameraLink and ADPCO
Hi Mark,
Ø  I am in the process of attempting a modern deployment of AD, but in all cases so far (AD 2-6 through AD 3-3-2), the images just buffer up to memory.
Can you explain what you mean by "images just buffer up to memory"?
Ø  I am assuming that it broke when you implemented threading, but since PCO is derived from CameraLink, I am not sure which module or code needs to be corrected.
I'm not sure what you mean by "implemented threading".  I added support for multiple threads per plugin in ADCore R3-0, but that has nothing to do with drivers.
Ø  but I never understood how this worked even when it was working.
What are you referring to when you say you did not understand how it worked?  The CameraLink and ADPCO driver, or threading?
Ø  The last known to be working legacy version on the systems in question seem to date back to AD 2-2
ADCore R2-2 is from March 23, 2015.  There are a number of working drivers (e.g. marCCD) that have no substantial changes since 2014.  Thus, I don't think there were any changes to ADCore since R2-2 that should have broken the drivers you are working on.
Sent: Friday, October 5, 2018 4:24 PM
To: [email protected]; Mark Rivers <[email protected]>
Subject: CameraLink and ADPCO
Mark -
Question.
CameraLink and ADPCO have been effectively untouched for the last 2 years.  I am in the process of attempting a modern deployment of AD, but in all cases so far (AD 2-6 through AD 3-3-2), the images just buffer up to memory. The last known to be working legacy version on the systems in question seem to date back to AD 2-2.
I am assuming that it broke when you implemented threading, but since PCO is derived from CameraLink, I am not sure which module or code needs to be corrected. I know that generally, all that is required is perhaps the number of parameters tweaked, and some return values changed, but I never understood how this worked even when it was working.  Any insight on what, in general, I should be looking for?
[cid:[email protected]]
PNG image
CameraLink and ADPCO Engbretson, Mark S.
RE: CameraLink and ADPCO Mark Rivers
Prev: Re: Base R3.15.6-rc1 Published Johnson, Andrew N.
Next: about talking to other record in device support and converting string to int ori spokoini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CameraLink and ADPCO Engbretson, Mark S.
ANJ, 07 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
