1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
Subject: RE: CameraLink and ADPCO
To: "'Engbretson, Mark S.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 Oct 2018 21:47:36 +0000
Hi Mark,
Ø  I am in the process of attempting a modern deployment of AD, but in all cases so far (AD 2-6 through AD 3-3-2), the images just buffer up to memory.
Can you explain what you mean by “images just buffer up to memory”?
Ø  I am assuming that it broke when you implemented threading, but since PCO is derived from CameraLink, I am not sure which module or code needs to be corrected.
I’m not sure what you mean by “implemented threading”.  I added support for multiple threads per plugin in ADCore R3-0, but that has nothing to do with drivers.
Ø  but I never understood how this worked even when it was working.
What are you referring to when you say you did not understand how it worked?  The CameraLink and ADPCO driver, or threading?
Ø  The last known to be working legacy version on the systems in question seem to date back to AD 2-2
ADCore R2-2 is from March 23, 2015.  There are a number of working drivers (e.g. marCCD) that have no substantial changes since 2014.  Thus, I don’t think there were any changes to ADCore since R2-2 that should have broken the drivers you are working on.
Sent: Friday, October 5, 2018 4:24 PM
To: [email protected]; Mark Rivers <[email protected]>
Subject: CameraLink and ADPCO
Mark –
Question.
CameraLink and ADPCO have been effectively untouched for the last 2 years.  I am in the process of attempting a modern deployment of AD, but in all cases so far (AD 2-6 through AD 3-3-2), the images just buffer up to memory. The last known to be working legacy version on the systems in question seem to date back to AD 2-2.
I am assuming that it broke when you implemented threading, but since PCO is derived from CameraLink, I am not sure which module or code needs to be corrected. I know that generally, all that is required is perhaps the number of parameters tweaked, and some return values changed, but I never understood how this worked even when it was working.  Any insight on what, in general, I should be looking for?
RE: CameraLink and ADPCO Engbretson, Mark S.
Re: CameraLink and ADPCO Mark Rivers
Prev: CameraLink and ADPCO Engbretson, Mark S.
Next: RE: CameraLink and ADPCO Engbretson, Mark S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024
ANJ, 06 Oct 2018 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
