1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS data browser to MySQL connection
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Vishnu Patel <[email protected]>
Cc: techtalk <[email protected]>
Date: Wed, 10 Oct 2018 12:41:02 +0000
To avoid the "Cannot write password" error from the UI, check that the installation folder is writable.
>   I tried with new workspace and command line, setting password in file the result below
> css-4.5.0$ ./css -pluginCustomization setting.ini
Use /the/full/path/to/your/settings.ini, not just settings.ini .
From http://cs-studio.sourceforge.net/docbook/ch06.html#sec_cmdline_plugin_customization :
...  always provide the full name to the file, even if it is in what you consider the current directory, because the Java runtime that is started by the Eclipse RCP launcher could have a very different idea of its current directory.
If Eclipse does not find your -pluginCustomization file, it is simply ignored, there will be no error message! So if the settings that you think you put into a -pluginCustomization file are not having the desired effect, triple check that you indeed provided the full and correct path to the file.
-Kay
Re: CSS data browser to MySQL connection J. Lewis Muir
Re: CSS data browser to MySQL connection Vishnu Patel
Re: CSS data browser to MySQL connection Kasemir, Kay via Tech-talk
Prev: EPICS Collaboration Meeting Registrations Now Open [SEC=UNCLASSIFIED] POZAR, Andraz
Next: Re: CSS data browser to MySQL connection J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS data browser to MySQL connection Vishnu Patel
ANJ, 10 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
