1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions about install
To: [email protected]
Date: Wed, 10 Oct 2018 10:18:30 -1000
On 10/10/18 04:30, Lucock, Richard M wrote:
   If $(TOP) is not equal to $(INSTALL_LOCATION), you cannot see startup
directory in 3.15.5 and 7.0.1.1. From our environment, we create that
directory, and copy EpicsHostArch.pl file into it.
   From 3.15.6-rc1, EpicsHostArch will be in startup directory if $(TOP)
is equal to $(INSTALL_LOCATION). However, if $(TOP) is not equal to
$(INSTALL_LOCATION), we cannot see "startup" path in
$(INSTALL_LOCATION). However, EpicsHostArch.pl file will be copied into
$(EPICS_BASE)/lib/perl path.
   Thanks for that, at least I know I'm not doing something wrong.
I partially circumvented this by copying a lot of stuff from the
source tree to the install tree. For as long as I have used EPICS
we have always had separate source trees and install trees and I'm
not willing to abandon that concept - we do that for the rest of
our software as well.
At some point in the extensions I got stuck - and then side-tracked
into other stuff that also needed to be done.
I hope to get back to that soon-ish (upgrading from 3.13.8) and I
hope that there are others struggling with the same concept and
maybe having come up with other solutions. I do not consider
installing into the source tree a solution.
Maren
Re: Questions about install Johnson, Andrew N.
Re: Questions about install Michael Davidsaver
Questions about install Lucock, Richard M
Re: Questions about install Jeong Han Lee
Re: Questions about install Lucock, Richard M
Prev: Re: Questions about install Lucock, Richard M
Next: Re: Questions about install Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 10 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
