1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Camera Recommendations [SEC=UNCLASSIFIED]
To: "'POZAR, Andraz'" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Wed, 17 Oct 2018 16:04:51 +0000
Hi Andraz,
I have 4 more questions:
- Is your camera connected point-to-point with a dedicated NIC, or is it on a network with other devices?
- Have you enabled jumbo packets on the NIC?
- Have you followed the recommendations in this Point Grey article for system network buffer sizes?
https://www.ptgrey.com/KB/10016
- Are you seeing error messages about "Image inconsistency" indicating dropped frames?
I have found that Point Grey cameras work best when using a dedicated connection, jumbo frames, and increased Linux network buffers.  They seem to be less tolerant than AVT/Prosilica cameras of other traffic on busy networks.
-----Original Message-----
Sent: Wednesday, October 17, 2018 7:47 AM
To: 'POZAR, Andraz' <[email protected]>; [email protected]
Hi Andraz,
> we have tried using BFLY-PGE-13S2M-CS with adSpinnaker on Ubuntu 16
> and FL3-GE-13S2M-CS with adPontGrey on Centos 7 but both of them "freeze" after running smoothly for some time.
> They become unresponsive and an IOC reboot is required in some cases even power cycle of the camera.
That's interesting.  I have some questions about this:
- What is the approximate mean time it takes for the camera to freeze?  I would like to try to reproduce the problem and want to know how long I would need to test.
- Have you tried running the Point Grey software, either FlyCap2 or SpinView with these cameras?  Does that also freeze?  That would tell us if it is a problem with the hardware or their library, or the EPICS software.
- Have you tried running the aravisGigE software?  That would also help to see where the problem is.
I own several of the BlackFly GigE cameras, but I am using them for development, not in production, so I have not run them for a long time where I might observe this.
However, I am using Point Grey Grasshopper3 cameras in production, both GigE and USB3 versions.  Right now I have a GS3-U3-23S6M that has run for 42 days at 100 frames/s with no problems.  That is running ADPoinyGrey on Centos 7.  I use the same model for tomography with ADPointGrey on Windows where I typically collect 200GB/day with no issues.  I also have 2 GS3-PGE-23S6C (GigE) cameras that have run for 15 days at 46 frames/s with no problems.  Those are running ADPointGrey on Windows.
Sent: Tuesday, October 16, 2018 5:01 PM
To: Mark Rivers <[email protected]>; [email protected]
Hi Mark,
Thank you for recommendation, however, we have tried using BFLY-PGE-13S2M-CS with adSpinnaker on Ubuntu 16 and FL3-GE-13S2M-CS with adPontGrey on Centos 7 but both of them "freeze" after running smoothly for some time. They become unresponsive and an IOC reboot is required in some cases even power cycle of the camera.  We're running them at toughly 1 Hz so they should get overworked.
At this stage we're looking at potential alternatives or any kind of advice if someone has had similar experience with those cameras?
Cheers,
Andraz
Sent: Tuesday, October 16, 2018 10:45 PM
To: POZAR, Andraz <[email protected]>; [email protected]
Subject: Re: Camera Recommendations [SEC=UNCLASSIFIED]
Hi Andraz,
The Point Grey Blackfly cameras will meet your specifications:
https://www.ptgrey.com/blackfly-gige-poe-cameras
Here are 2 examples:
BFLY-PGE-13S2M-CS
1/3 inch, global shutter, 1288x964 pixels
3.75 micron pixels
66% QE, 11 e- read noise, 9339 e- full well
58 dB dynamic range
30 FPS
POE
$345
The following model has significantly better QE, read noise, and dynamic range in a somewhat larger format:
BFLY-PGE-23S6M-C
1/1.2" sensor, global shutter, 1920x1200 pixels
5.86 micron pixels
80% QE, 7 e- read noise, 33105 e- full well
73 dB dynamic range
41 FPS
POE
$495
Either camera can be used with 3 areaDetector drivers:
ADPointGrey (Windows, Linux RHEL 7 or higher) aravisGigE (Linux, most any version) ADSpinnaker (Windows, Linux Ubuntu 16 and higher)
From: [email protected] <[email protected]> on behalf of POZAR, Andraz <[email protected]>
Sent: Tuesday, October 16, 2018 12:44 AM
To: [email protected]
Subject: Camera Recommendations [SEC=UNCLASSIFIED]
Hi all,
We're looking into replacing our old Firewire cameras with Ethernet ones and we'd be interested in any suggestions and experiences you have had with different camera models.
Some requirements:
-          1/3 inch, global shutter, mono sensor at roughly 1300 x 900 resolution
-          Good quantum efficiency and low noise
-          Roughly 4 microns pixel size
-          Ethernet
-          Preferably POE
-          areaDetector support
Cheers,
Andraz Pozar
Controls Engineer
Australian Synchrotron
Tel
Email
Web
+61 3 8540 5387
[email protected]<mailto:[email protected]>
www.ansto.gov.au<http://www.ansto.gov.au/>
[fb]<http://www.facebook.com/DiscoverANSTO> [tw] <https://twitter.com/ANSTO>  [ln] <http://www.linkedin.com/company/ansto>  [yt] <http://www.youtube.com/user/ANSTOVideos>
[ansto]
Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
RE: Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
Re: Camera Recommendations [SEC=UNCLASSIFIED] Wayne Lewis
Re: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
RE: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Prev: RE: Camera Recommendations [SEC=UNCLASSIFIED] Mark Rivers
Next: medm color map question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Camera Recommendations [SEC=UNCLASSIFIED] Engbretson, Mark S.
Next: RE: Camera Recommendations [SEC=UNCLASSIFIED] POZAR, Andraz
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
