1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Current Source / Power supply suggestion
From: "Stubbs Scott Allen (PSI)" <[email protected]>
To: Nilson Pereira <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 8 Nov 2018 18:00:05 +0000
Hi Nilson
I double the Sorensen recommendation, they are quite reliable in my experience and only needs a simple set of controls.
Also, some Keysight power supplies (e.g. E3642A) perform well and offer RS-232/GPIB, if that is more your speed.
Cheers
Scott
From: [email protected] [[email protected]] on behalf of Nilson Pereira [[email protected]]
Sent: Wednesday, November 07, 2018 5:09 PM
To: [email protected]
Subject: Re: Current Source / Power supply suggestion
Thank you Mark, Rod, Kurt and Heinz for the suggestions.
I will take a look at all suggested options:
- Caenels FAST-PS (LAN)
- Sorensen XHR Series (Analog+RS232)
- Manson HCS Series (Analog+USB)
- BK Precision (Analog+USB)
- Keysight/Agilent (LAN)
I have some EPICS controlled analog outputs available to use with the
more affordable type of power supplies, so all options are valid.
Thanks again for the help.
Best
Nilson
On 07.11.18 15:45, Goetze, Kurt wrote:
> Hi Nilson,
> We have written RS232 support for the BK Precision 9173B, and deployed this device on APS beamlines for applications similar to yours.
> https://www.bkprecision.com/products/power-supplies/9173B-two-channel-dual-range-dc-power-supply-10v-10a-20v-5a.html
> The 9131B is also supported:  (click on the "Models" tab)
> https://www.bkprecision.com/products/power-supplies/9130B-triple-output-programmable-dc-power-supplies.html
> You can find the BK 9173B EPICS support in the synApps/IP module on github:
> https://github.com/epics-modules/ip
> The 9131B support is not in github yet but I will put it in there.  These are fairly inexpensive compared with other options out there with similar specs.  Not sure about their availability in Europe, but here we can get them through the big electronics distributors.
> Kurt
> -----Original Message-----
> From: [email protected] <[email protected]> On Behalf Of Nilson Pereira
> Sent: Wednesday, November 7, 2018 6:49 AM
> To: Tech-talk <[email protected]>
> Subject: Current Source / Power supply suggestion
> Dear All,
> I am developing a temperature control solution based on peltier elements. The PID loop will control the current on the peltier elements based on the target temperature.
> What I am really looking for are suggestions for remote control linear DC Current source (0-5A, >300W) or Power supply with available EPICS drivers.
> Any information will be truly appreciated. (Bonus for being easily available in europe)
> Thank you.
> Best regards,
> Nilson Pereira
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> https://www.helmholtz-berlin.de
> Abonnieren Sie unseren monatlichen Newsletter!<https://www.helmholtz-berlin.de/aktuell/pm/newsletter/>
> Subscribe to our monthly newsletter!<https://www.helmholtz-berlin.de/aktuell/pm/newsletter/index_en.html>
Postadresse:
D-14109 Berlin
Current Source / Power supply suggestion Nilson Pereira
RE: Current Source / Power supply suggestion Goetze, Kurt via Tech-talk
Re: Current Source / Power supply suggestion Nilson Pereira
Prev: Open Computer Engineering position at PPPL Greg Tchilinguirian via Tech-talk
Next: P4P release 3.0.0 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Current Source / Power supply suggestion Nilson Pereira
Next: Re: Current Source / Power supply suggestion Heinz Junkes
ANJ, 08 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
