1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: P4P release 3.0.0
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 8 Nov 2018 18:00:55 -0800
I'd like to announce the availability of P4P (PVAccess for Python)
library version 3.0.0.  Quite a bit of work has been done since the
previous 1.0 release.  Thanks to DLS for supporting this work.
https://mdavidsaver.github.io/p4p/
The headline features are support for running PVA servers, interop
with the asyncio and cothread concurrency libraries, support for
Windows and OSX* as well as Linux, and packaging via pypi.org.
The last point means that investigating P4P starts with a simple:
> pip install p4p
No other setup is required.
See the quickstart section for where to go from there.
https://mdavidsaver.github.io/p4p-dev/starting.html
Alternately, P4P can be built as an EPICS module in the usual way.
https://github.com/mdavidsaver/p4p/releases/tag/3.0.0
* I'm interested in OSX test results as I have a report
  of a strange failure from one user.
Re: P4P release 3.0.0 Heinz Junkes
Prev: RE: Current Source / Power supply suggestion Stubbs Scott Allen (PSI)
Next: NSLS2 EPICS trainings by Tim Mooney Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Open Computer Engineering position at PPPL Greg Tchilinguirian via Tech-talk
Next: Re: P4P release 3.0.0 Heinz Junkes
ANJ, 09 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
