Hello, I want to control an ABB AC500 PLC by EPICS through TCP/IP, so I use modbus support from Mark Rivers. I do a little modifications to "Koyo1.cmd" scripts but things do not go well. PLC can be connected by asyn ip port but it shows "Connection reset by peer" when asyn modbus port connects to registers in PLC. I googled this and is told that the reason may be that response telegrams contain RST signal. This error might be a protocol problem. As mentioned in documents, this modbus support does not support Siemens PLC. Is ABB PLC also not supported? The default port of AC500 PLC is 1201, not 502,as shown below. Does this matter? Thank you for any help, Jasper Here are my *.cmd and *.substitutions scripts: #! ../../bin/linux-x86_64/modbusApp dbLoadDatabase("../../dbd/modbus.dbd") modbus_registerRecordDeviceDriver(pdbbase) drvAsynIPPortConfigure("AC500","192.168.0.10:1201",0,0,1) #asynSetOption("AC500", 0, "disconnectOnReadTimeout", "Y") modbusInterposeConfig("AC500", 0, 5000, 0) drvModbusAsynConfigure("AC_DW1", "AC500", 0, 4, 0, 1, 0, 100, "AC500") drvModbusAsynConfigure("AC_DW2", "AC500", 0, 4, 1, 1, 0, 100, "AC500") asynSetTraceIOMask("AC500", 0, 4) asynSetTraceIOTruncateSize("AC500", 0, 512) dbLoadTemplate("abb.substitutions") iocInit -------------------------------------------------------------------------------------------------------------- file "../../db/longin.template" {pattern {P, R, PORT, OFFSET, SCAN,} {AC500:, DW1, AC_DW1, 0, "I/O Intr",} {AC500:, DW2, AC_DW2, 0, "I/O Intr",} } Here is the iocShell output: #! ../../bin/linux-x86_64/modbusApp dbLoadDatabase("../../dbd/modbus.dbd") modbus_registerRecordDeviceDriver(pdbbase) drvAsynIPPortConfigure("AC500","192.168.0.10:1201",0,0,0) #asynSetOption("AC500", 0, "disconnectOnReadTimeout", "Y") modbusInterposeConfig("AC500", 0, 5000, 0) drvModbusAsynConfigure("AC_DW1", "AC500", 0, 4, 0, 1, 0, 100, "AC500") drvModbusAsynConfigure("AC_DW2", "AC500", 0, 4, 1, 1, 0, 100, "AC500") asynSetTraceIOMask("AC500", 0, 4) asynSetTraceIOTruncateSize("AC500", 0, 512) dbLoadTemplate("abb.substitutions") iocInit Starting iocInit ############################################################################ ## EPICS R3.16.1-DEV ## EPICS Base built Oct 24 2018 ############################################################################ 2018/11/16 10:22:35.526 drvModbusAsyn::doModbusIO port AC_DW1 error calling writeRead, error=192.168.0.10:1201 read error: Connection reset by peer, nwrite=6/6, nread=0 2018/11/16 10:22:35.580 drvModbusAsyn::doModbusIO port AC_DW2 error calling writeRead, error=192.168.0.10:1201 read error: Connection reset by peer, nwrite=6/6, nread=0 iocRun: All initialization complete epics>
ANJ, 15 Nov 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
