This page says that ACC AC500 communications modules do support Modbus TCP
https://new.abb.com/plc/programmable-logic-controllers-plcs/ac500/communication-modules
It appears that CPU modules with Ethernet support Modbus, as does the CM597 module.
I think that Modbus will always use port 502. If you are using a different port it is probably a different protocol.
From: [email protected] <[email protected]> on behalf of 黄佳伟 <[email protected]>
Sent: Thursday, November 15, 2018 8:30 PM
To: [email protected]
Subject: modbus connection error to ABB PLC
Hello,
I want to control an ABB AC500 PLC by EPICS through TCP/IP, so I use modbus support from Mark Rivers. I do a little modifications to "Koyo1.cmd" scripts but things do not go well. PLC can be connected by asyn ip port but it shows "Connection reset by peer" when asyn modbus port connects to registers in PLC. I googled this and is told that the reason may be that response telegrams contain RST signal. This error might be a protocol problem.
As mentioned in documents, this modbus support does not support Siemens PLC. Is ABB PLC also not supported? The default port of AC500 PLC is 1201, not 502,as shown below. Does this matter?
Thank you for any help,
Jasper
Here are my *.cmd and *.substitutions scripts:
#! ../../bin/linux-x86_64/modbusApp
dbLoadDatabase("../../dbd/modbus.dbd")
modbus_registerRecordDeviceDriver(pdbbase)
drvAsynIPPortConfigure("AC500","192.168.0.10:1201",0,0,1)
#asynSetOption("AC500", 0, "disconnectOnReadTimeout", "Y")
modbusInterposeConfig("AC500", 0, 5000, 0)
drvModbusAsynConfigure("AC_DW1", "AC500", 0, 4, 0, 1, 0, 100, "AC500")
drvModbusAsynConfigure("AC_DW2", "AC500", 0, 4, 1, 1, 0, 100, "AC500")
asynSetTraceIOMask("AC500", 0, 4)
asynSetTraceIOTruncateSize("AC500", 0, 512)
dbLoadTemplate("abb.substitutions")
iocInit
file "../../db/longin.template" {pattern
{P, R, PORT, OFFSET, SCAN,}
{AC500:, DW1, AC_DW1, 0, "I/O Intr",}
{AC500:, DW2, AC_DW2, 0, "I/O Intr",}
Here is the iocShell output:
drvAsynIPPortConfigure("AC500","192.168.0.10:1201",0,0,0)
iocInit
Starting iocInit
## EPICS R3.16.1-DEV
## EPICS Base built Oct 24 2018
2018/11/16 10:22:35.526 drvModbusAsyn::doModbusIO port AC_DW1 error calling writeRead, error=192.168.0.10:1201 read error: Connection reset by peer, nwrite=6/6, nread=0
2018/11/16 10:22:35.580 drvModbusAsyn::doModbusIO port AC_DW2 error calling writeRead, error=192.168.0.10:1201 read error: Connection reset by peer, nwrite=6/6, nread=0
epics>
- modbus connection error to ABB PLC 黄佳伟
Re: EPICS Application Package Benjamin Franksen
<2018>
job opportunities at ORNL Hartman, Steven M. via Tech-talk
<2018>
